Question about Reddy Heater R70 Portable Forced Air Space Heater - 70,000 BTU
I have a reddy heater model R70 that wont ignite.
The spark plug fires but nothing else happens. I used it a couple of weeks ago and it worked fine, now nothing.
  • PaulIII Jan 17, 2009
    I have the same problem. I have spark but it seems like no fuel is coming thru the tubing.
If the motor runs and you have spark it could be you have a broken rotor located on the end of the motor in back of the air filter. Unit will not pump fuel if rotor is not turning. I have a 90,000 with the same problem and a new rotor did the trick
Posted on Jun 19, 2010
I have the same problem. What is the matter with it? It seems like it will not pump fuel.
Posted on Jan 17, 2009
I have an r-50. It just won't turn on. It worked fine last winter
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 11, 2010 | Reddy Heater R70 Portable Forced Air Space...
Space heater is smoking smelling
heatman101
Nov 10, 2010 | Reddy Heater R70 Portable Forced Air Space...
HAVE REDDY 55, I GET NO FIRE TO THE SPARK PLUG,
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 20, 2009 | Reddy Kerosene Heater with Thermostat:...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
WONT FIRE
have you cleaned the air inlets? I have a older (1970's) reddy heater, occasionally it starts getting smokey or not firing at all. I open up where the air filter is and clean out the chamber with carb cleaner; gets the old girl firing up nice again.
Jan 07, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Won't light/stay on
It may be the spark plug (or the ignition module). On my Reddy Heater 50K BTU, there are six metal screws that join the top of torpedo tube to the bottom. Remove these,and the top of the tube casing. The spark plug should be in plain sight.
Turn the unit on and look for spark. If it's not firing, replace the plug. If it still doesn't fire, you may need to replace the ignition module (it's what is "connected to the spark plug via the fat ignition wire.")
Hope this helps,
Jan 06, 2009 | Dayton E50 Heater
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Heating & Cooling Logo
236 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
