Question about Toshiba 55H70 55" Rear Projection Television
Mitsubishi VS-45609 Blue layer is distorted and seperated
The blue layer of the screen is warped leading to a seperation of the viewing image. I was wondering if anyone had any suggestions, I've heard that it may be a convergance IC. If it is I would like to know what part I should order and maybe where I can find it on the TV board.
Thanks,
Double_G
  • Toshiba Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Mitsubishi VS-45609 Blue layer is distorted and se - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 03, 2010
Curved/warped and completely out of convergence Image
Sounds like you need the convergence amplifiers replaced. Cost approx. $300.00 for expert to repair.
Jun 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Green color seperation multiple images convergence will not fix
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
Sudden blue shift
Use the 180's. I've just replaced mine and everything runs fine. I've heard they run cooler.
Sep 08, 2008 | Panasonic PT-47WX53 47" Rear Projection...
DSC P51
There is a seperate microphone to do that. Usually when the CCD imager is bad it cause a white screen to appear or the colors are distorted in the view finder.
I would take it into a camera shop and see what they say unless the battery hasn't been replaced recently.
Jun 27, 2008 | Sony Cyber-Shot DSC-P51 Digital Camera
I recently purchased an RCA rear-projection TV from a friend, and I'm having some trouble with the convergence. It's model # P60925BL, serial #904251165. When I try to use it, the red and blue convergence...
since two colors are affected I would suggest checking the solder on the convergence power supply. If the solder is good you will most likely need a new power supply. The power supply board is the one without all the heatsinks next to the convergence board
Jun 24, 2008 | RCA Televison & Video
Magnavox big screen tv
Yes the blue most often get a ick coating 1st
it needs to be drained/cleaned and refilled.
It likely not something you can do yourself.
Jan 27, 2008 | Televison & Video
45" Rear projection image warping
you can check the self diagnostic test by going to ctechnicians.com
Dec 22, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Blue color warps screen
Blue convergence IC bad....change both IC's and check
current limiting resistors for over-heating.....let me know if
you need more info..........................T.
Oct 21, 2007 | Philips 50PP9202 50" Rear Projection...
Sky 42 inch plasma tv
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Sep 06, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
EVOLT E-500 LCD Problem (Mirror Image)
This is new one one. It would seem to be an electronic failure of some sort Suggest you refer to Olympus Support on this one
Aug 20, 2007 | Olympus EVOLT E-500 Digital Camera
Toshiba 55H70 55" Rear Projection Television Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
