Question about Haier BC112G Wine Cooler
Haier Wine Fridge problem
Thought I would ask if you knew what is wrong with my wine Fridge. Just noticed the LED display says "LL" and when I try to reset the temp (which I originally had at 55 degrees) it says the current temp is 27 degrees. Any thoughts? Thanks so much
  • Anonymous Apr 04, 2009
    Excessive condensation on the front door and LED display says "LL" Very cold inside. Tried to unplug and replug to clear the display. Still shows "LL" when restarted.
  • wwheat2 May 11, 2010
    Changed thermostat got the same problem????
  • 750 Answers
Hello bano24
Welcome to Fixya
My name is Huum,
You have a faulty cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
Check the control for continuity.
And or need a hands on service tech to diagnose this fault
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Dec 31, 2008
What does it mean when "LL" shows up in the temp light box? Also the wine fridge was very cold with condensation inside and out. We just got home from a week away and noticed a high whining sound as well.
You may have had a power surge or outage while you were gone. The temp sensor may have failed or the control board may have failed. Either way, the code means that the temp in the frig is not the temp that it is set to be.
Dec 01, 2013 | Haier BC112G Wine Cooler
The temp is 25 and is stuck on LL
replace the temp sensor first
$4.76 from Haier part# RF-6250-01
still stays at 25 degrees?
replace the control board & you should be done.
$26.81 from Haier part# RF-0668-04
Oct 23, 2011 | Haier BC112G Wine Cooler
My Haier Wine Cooler HVFM30A the compressor or motor over heated and stop working. Can I replace it?
A new compressor for that unit from Sears parts direct costs $206.
The unit itself is worth around $233 and is no longer in production.
After you pay someone to replace the compressor you'll have spent way more than it is worth.
Your best bet is to get a new wine cooler.
TickMagnet
Aug 20, 2011 | Haier HVFM30A Wine Cooler
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Dec 31, 2010 | Haier BC112G Wine Cooler
Light stays on. It was flashing LL for the lower
the first step is shutting it off for 24 hours with the door open to make sure there is not any ice on the evaporator. next, make sure the door seal is sealing properly. if neither of those are the culprit, you may need a new thermostat.
Nov 06, 2009 | Haier HVZ040ABH5S Stainless Steel Wine...
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
Haier wine cooler
Haier BC112G service & user manual:
To adjust the temp of your unit:
  • Push & hold the red wine & white wine button at the same time.This will start the temp adjust. You will notice the plus sign & the negative sign on these same buttons, use them to adjust temp. When you are done hit the light button & it will record the new temp.
Nov 25, 2007 | Haier BC112G Wine Cooler
Lost manual for wine fidge
Push the red and white buttons at the same time for about 3 seconds-the temp will start to flash-then press the white button to lower the set temp-when you have it where you want it then push the set buttom
Oct 18, 2007 | Haier HVF060A Wine Cooler
Haier BC112G Wine Cooler Logo
636 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
