Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No picture or menu
The sound is fine, the tuneer changes channels. however we cannot get a picture nor a menu to change video channels. it will change video channels but we cannot see the change.hope you can help. sony bravia lcd 40inch Howard
  • 1 more comment
  • usman747 Aug 27, 2008
    I HAVE SAME PROBLEM WITH THE KDL40V2000U. WHEN I TURN THE TV ON, THERE IS NO PICTURE AT ALL, JUST A BLACK SCREEN. BUT I CAN HEAR THE SOUND PROPERLY. I WONDER WHAT THIS CAN BE? IS THERE SOME SORT OF LAMP THAT COULD'VE BLOWN? I HAVE HAD THIS TV FOR NEARLY 2 YEARS NOW AND IS OUT OF WARRANTY. HOW MUCH WOULD IT COST TO REPARE? THANKS ALL IN ADVANCE
  • Anonymous Sep 23, 2008
    I have the same problem, but I have an extended 3 year warranty. The service company now has the TV. My TV was 28 mos old.
  • Anonymous Oct 08, 2008
    i have a Sony KDL-40S2010 that has no picture and no menu. The sound work s fine. I can hear the channels change, but I can't see it. It's only about 14 mos old.
    Problem Solver:
  • 8 Answers
If your dealer has not already told you, I suggest you unplug the unit from the wall and let it sit for 30-45min. Plug it back in and hope...
Posted on May 04, 2007
The TV has perfect picture but no sound how do I get the sound back on
Are you by chance on the SAP audio channel instead of the main channel? You should be able to go into the menu and look at the audio settings. If you are on SAP change it back to main. Some stations do not have audio on the SAP channel.
Jan 20, 2017 | Televison & Video
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
Jul 01, 2009 | Philips 32PW6506 32" TV
''Hotel'' Viewing mode on Akai TV Model #CTS2550
Did you get an owners manual with the television?
Jul 01, 2017 | Akai CTS2550 25" TV
No sound for my ps3
There's a set-up menu in your ps-3, you have to change the menu from analog to digital output.
Kind regards, Gerard
Oct 19, 2008 | LG 42LC2D 42 in. LCD HDTV
HAVE PICTURE BUT NO SOUND
check for center channel option in menu, change option and test
May 21, 2007 | JVC AV-56WP30 56" Rear Projection...
White Noise Sound
Your problem is somewhere between the tuner and video detector circuit. The signal entering your TV carries: video,red color,and blue color as well as sychronizing pulses for color and horizontal and vertical deflection ( actually vertical sync. is derived from horizontal sync.) along with burst pulses to synchronize the color. After all these, the sound is an fm signal entwined with a pilot signal for stereo audio. WHAT a mess! After the audio passes through all this, it is detected and sent to the audio processor. If any frequency has drifted away from it's value then you loose the sound. SO... your problem could be in any of the tuned circuits or in the audio processor IC (chip). Any component changing value could creat this problem. Most likely the audio processor IC. You'd need to have the set checked out by a tech to find your problem. Stargazer
Mar 11, 2007 | Proscan PS32600 32" TV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
188 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
