Need to start roof job tomorrow. Was told at lumber yard that roofing nails would work in this gun. I think the heads are to big to pass through the driver.
SOURCE: will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
SOURCE: How to fix a bostich roofing nail gun that leaks
You need a refit kit to suit that gun which comes with new gaskets to prevent air leaks.
SOURCE: my brand new bostich roofing gun froze up after
Water in gun or wrong oil for cold temp will cause gun to freeze. Make sure that the compressor is not making water form in hoses due to hot air entering cold hose then freezing in gun. Remove cap of nailer and check for water and lube with light oil that remains liquid in your temp range. If the oil is too thick, the firing valve under trigger and headvalve will not budge. Use very short hose so warm air in tank can reach the nailer (heat is produced when air is compressed, however long hose will allow air to cool before entering gun). Stay warm and good holidays
SOURCE: nail gun not putting nail in all the way
you need to disassemble de gun,
once you take the rod that pushes the nails. you'll see that at the end of it its threaded that is the adjuster
you just turn it the way it needs to go. it is pretty simple what takes you more time is the disassemble process and of course putting everything back together.
