Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 Washer door will not open
The door is locked shut
    Sergeant:
  • 311 Answers
Chris unplug unit.take off bottem paneland reach up in door latch area.their is a tab you can pull to open locked door.is the washed draining.you may need to clean pump if not.God bless,tom
Posted on Jan 01, 2009
DRYER DISPLAYS CODE F22. What does this mean?
"F22" is a door lock issue Press the "Stop" button twice to cancel the cycle if "F22" shows. Check that the washer door is firmly shut--open it and shut it and try again. Make sure there aren't items blocking the closing of the door. Don't overload the basket. Try the cycle again.
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
He3 washer will not start. The lights on the
you probably broke the door switch and the machine thinks the door is open. little piece on top of the lock catch. need to change the door switch
Feb 05, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 washer door will not open
The error code F-02 on the Kenmore HE3 means that the drain pump could not pump out all the water within 8 minutes. Not sure what this has to do with the door being locked,, but its also possible that if the machine thinks there is still water in the drum, or if in fact there is still water in the drum that it would keep the door locked as some sort of safety precaution
Mar 13, 2009 | Washing Machines
Kemore HE3 front load washer won't start
Check you door latch. When you open the door, there should be a black square hole on the frame and a black round hole above it with a pin sticking out. The pin is probably broken off and the door latch assembly needs to be replaced.
Jun 03, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Door locked with door open
if you have already tried leaving unpluged for hour or so new lock is in order..pull spring off door seal around edge ..roll seal back 2 torx screws hold lock in placed 2-3 plugs attached to lock..fun comes getting spring on but actually not that hard 4 hands make it easier
Apr 27, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Buttons lit up, washer not going
If nothing works, no water and no motor action, then it sounds like a door switch or door lock problem. Check to make sure door is properly shut and switch is operating.
Feb 28, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Door lock
try crc into lock
if no good replace door lock
Nov 16, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 lock
Have you tried pushing the door lock/unlock button? I think it may be called the "rinse & spin", and under that it says door lock/unlock.
Sep 20, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
88 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
