Thermostat hookup
There will be none commercially available. You need to use the diagram that came with the thermostat and the diagram on the access panel of the furnace. Typically Red goes to R, Green goes to G and so forth. Red and White are your heat cycle wires. Red and Yellow are your cooling and the Green is to operate the blower. If only 4 wires, you need a jumper at the thermostat going from R1 to R2. Check the connections at the furnace to make sure they are attached the typical way prior to attaching them to the thermostat.
