Philips 60PP9202 60 in. Rear Projection HDTV-Ready Television
Problem for Philips 60PP9202 60 in. Rear Projection HDTV-Ready...
Phillips 60PP920217F Convergence Problems
By Smitty66 on May 03, 2007
My TV has a problem with the red and blue convergence and I cannot adjust vertical alligments so it looks like these are shot. Can anyone help? Does anyone know the part numbers of these (IC)units that I would need to repair? I hate to throw this unit away.
Thanks
Glen
Same Problem
Jan 02, 2009
-   I have the same convergance problem I just need to know what part numbers I need to fix it-   bec1059
Dec 31, 2008
-   My TV has a problem with the red, yellow, and blue convergence and I cannot adjust vertical alligments so it looks like these are shot. Can anyone help? Does anyone know the part numbers of these (IC)units that I would need to repair? I hate to throw this unit away.
-   ROSA RAMIREZ
Sep 27, 2008
-   I have a very similar problem, I have lost control of vertical convergence only. Horizontal works fine on both red and blue... Any idea why vertical only would go bad?
Thanks!-   mrfiksit
Jun 29, 2008
-   My convergence for both blue and red won't align repait @ $600(part chge 300/labor 300) repair folks say don't do it. this was a gift in2004/ I'm also told if I could find the "board" it's easy to solder on??-   nyazcndrela
Apr 15, 2008
-   I relpaced the 2 ic's for convergence and I can now adjust blue but red still will not adjust horizontally and is almost vertival with green but not exactly straight and alittle shorter than the green vertival line. What els should I replace to fix this and what are the locations and part #'s. half of the problem is fixxed.-   Freeebeee
Best Solution
posted on Jan 14, 2008
Very Helpful)
jsherman
Rank: Master
Rating: 96%, 8 votes
I have the same set and just fixed this problem toinght! I bought a couple of STK392-120s for $20 from www.electronix.com and with a soldering iron, heat sink compound and a solder sucker was able to do the job myself in a few hours. I did purchase the 6.8 ohm resistors too, but they all checked out find so I didn't replace them. There's a great site online at http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm that shows you the ropes, just not for this exact set. Once I did a multipoint reconvergence, the HD looks like new! This is at least a $600 service call from what I can gather, and if you're handy you can fix it yourself.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 16, 2007
Helpful)
Guest
Rank: Apprentice  Televisions & Videos  Expert
Rating: 0%, 0 votes
You are to change TWO IC'S for Convergence (Vertical & Horizontal) with IC (PHILIPS) 932212344682.
Please have a try!
Regards,
dsr,india
Solution #3
posted on Feb 14, 2009
Not Rated)
mrfiksit
Rank: Apprentice
Rating: 0%, 0 votes
Ok I got this all up and running. There is a wealth of info out there. All you need is to replace the convergence ICs I replaced mine with stk392-180s as the run cooler and can handle more voltage without blowing. Make sure to use very good thermal compound as it helps quite a bit with the coolring. There are also a few resistors you need to replace. You can find out all about this is you just google stk392-120 replacement. Google is ur friends ; )
Words to the wise be careful with your solder job.
Was this helpful?
Yes
No
Solution #4
posted on Jul 24, 2008
Not Rated)
yambo
Rank: Guru  Televisions & Videos  Expert
Rating: 85%, 77 votes
OK, friends. Time to fix it !!. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms. If you have questions? noetvs@embarqmail.com . Good Luck !!
Was this helpful?
Yes
No
Solution #5
posted on Jun 23, 2008
Not Rated)
AZEJ
Rank: Apprentice
Rating: 0%, 0 votes
I also relpaced the 2 ic's for convergence and I can now adjust blue but red still will not adjust horizontally. Any ideas?
Was this helpful?
Yes
No
Solution #6
posted on Dec 02, 2007
Not Rated)
waz-up man
Rank: Apprentice
Rating: 0%, 0 votes
replace ic chips pt# stk392-120 or stk392- 150 and there are 12 resistors located near ic clips pt# 6r8 ( color code blue - gray - gold - gold ) board location no#s 3149 thu 3160 if you look close you may find two resistors discolored as i found on my convergence circut board , also use heat sink compound on new ic chips , take your time to mark all wire connectors going to board from tv , also use .022 dia gage rosin -core solder and a 15- 25 watt soldering iron you may have to adjust the red - blue convergence afterwards my tv set is 3 yrs old also ( thanks holbert )
Comments:
Dec 02, 2007
- also i give holbert double fixya,s for all his help e-mail him hes great welch6@gmail.com happy holidays to all
Was this helpful?
Yes
No
Popular Solutions for Philips 60PP9202 60 in. Rear
Questions and Unsolved Problems for Philips 60PP9202 60 in. Rear
Do you recommend Philips 60PP9202 60 in. Rear Projection HDTV-Ready Television?
Answer
Answer
We have sound and no picture does this sound like the bulb is burned out.
10 Other Users Have The Same Problem - Continued
Comment by mikerr52, posted on Jan 14, 2008
i had green out lines i adjusted the blue and green points but they are not alined verticaly. what can i do?
Comment by Kay Jay, posted on Jan 13, 2008
Having green & red lines on everything and doubled picture
Comment by Guest, posted on Jan 12, 2008
First noticed that the picture had double images in red waves. checked convergence like the manual suggested. Couldn't get crosses to converge. The red cross in some areas of the screen looked like they were bent like wire.
Found this site listing 1 solution is to replace ic part # 93221234482 (does it take 2 of these?) which I found listed at the PARTS STORE web site, but the 2nd solution suggesting part # stk392-120 & stk392-150 & 12 resistors part # 6R8 would not come up in their listing. Which solution was successful and (if it's solution # 2) where do I get those parts?
Comment by djberg98, posted on Jan 08, 2008
Sounds like I am having the same problem. The red tube is like it is warped and will not adjust. How hard is it to fix? And what are the the part#'s and how much do they cost? I have the same model.
Comment by Guest, posted on Nov 25, 2007
I have the same problem, red and green will not aline.
how much should the cost to repair
AL
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(704) 315-5981
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
