Question about Dell (9K646) ATA Controller
DRIVE 0 not found
Please i changed my bad hard disk, and in rebooting i get this msg DRIVE 0 not found what should i do? press F1 to continue and F2 to go to SET UP.
  • 192 Answers
The first thing that you need to do is press F2 and go into the setup. The system may need to "discover" the drive so that it knows what is there.
There is usually a section for auto-detect on hardware and then it should find the drive listed. Then save the new settings (usually pressing F10 to save and exit) and then see if it boots up properly.
The computer will then boot up and should come up. Since this is a new drive, the system will not be able to start, since there is no operating system on the drive.
You will need your Windows CD handy so that you can re-install the OS and then go from there.
Posted on Dec 31, 2008
On the Boot-up screen I get the message: "Diskette
I think you should press F2 to go to the setup page.
There, you should change the order of your boot device.
set the first boot device to hard disk
set the second boot device to cd rom
and the third to floppy.
follow the instructions and click save and continue
Dec 22, 2010 | Dell Inspiron 530 Desktop Computer
When rebooting I get: Diskette drive 0 seek failure Press F1 to continue, F2 to enter SETUP
make sure there are no disks in your drives
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 28, 2010 | Computers & Internet
On startup a black screen with message "diskette drive seek failure" what does it mean? Then it says press F1 to continue or F2 to enter setup. I always press F1 and it starts up ok. this has only just...
This indicates that your computer is configured to boot on the floppy drive.
1. At the start of the computer Press F2
2. Go to the Boot Device Configuration.
3. Enable Hard Disk Boot Priority.
4. Set the First Boot Priority to Hard Disk
5. Save and Exit.
Please let me know of the outcome. Thank you and regards.
Aug 28, 2010 | Dell Inspiron 530 Desktop Computer
First you need to make sure that the CD drive is selected as the first boot device.
You can set that by going into BIOS setup by pressing Del/F2 during system startup OR during startup press F12 and select CD drive from the boot device selection menu.
Press Enter.
See if the system is able to start from the disc.
Feb 20, 2010 | Computers & Internet
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
Computer looking for a non-exsistant drive
Hi, the reason why you are getting the message is because the bios is set to seek the floppy disk and the setting is enabled and to resolve that you just need to disable the option on the bios
Entering the System Setup Program
  1. Turn on (or restart) your computer.
  2. When the DELL™ logo appears, press <F2> immediately.
  3. If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then, shut down your computer and try again.
Set the boot order to boot to the hard drive
And for the complete manual please visit
Jan 29, 2009 | Dell Inspiron 530 Desktop Computer
Dell GX270 Maxtor 7Y250M0
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
Dec 30, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Press F1 to continue and f2 to setup. How can i remove it please?
after pressing f2.....bios setup was opened.....go to drivers.....and than open diskette off .....your problam is solve 1000%
Dec 05, 2008 | 10 10 Computer Network adapter Cable...
I've installed a new hard drive and put in more RAM on my Desktop. Now i get this message WHAT DO I DO. The amount of system memory has changed. Primary hard disk drive 1 not found Strike the F1 key to...
Strike F2 to go to the bios to run the setup utility
Don't touch anything , save and reboot
If primary hard disk still not found
reboot press F2 to re-enter the bios
Look for Auto Detect Hard Disks
if the computer shows a hard drive is detected
set the drive to LBA if possible
save and reboot
Sep 15, 2008 | Computers & Internet
Dell (9K646) ATA Controller Logo
108 people viewed this question
Alun Cox
