Question about RCA RS2663 Shelf System
Cables with RCA on one end and Mp3 Player 3.5 mm connector other.
Where can I find the cable to connect a Mp3 player to the unit?
    Problem Solver:
  • 9 Answers
Try looking at radio shack for the cable. If not there you might try MCM Electronics on the web. If you have any soldering experience I know radio shack carries the parts to make one yourself.
Posted on Feb 18, 2009
How can I connect my I pod Touch to my Denon AVR 1803 receiver?
The best way to connect an older IPod or other MP3 player to the AVR-1803 is to use a 3.5 mm (M) to RCA audio cable. This will work for audio on all IPods (and video on some of the older IPods). Here's an example: http://www.amazon.com/3-5mm-Audio-Video-Cable-iPod/dp/B000STBSU4 . Connect the 3.5 mm end to the headphone jack; the RCA plugs go into one of the AVR-1803 RCA inputs.
For some IPods, try a connector like this: http://www.amazon.com/Cables-Unlimited-iPod-Connector-Cable/dp/B000CBFVXS . This connects to the docking port on the IPod.
I hope this helps.
Jul 20, 2015 | Denon Audio Players & Recorders
How to plug the blu-ray into the tv
It depends on the TV inputs. You will need to provide your own cables for most connections. If your TV has an HDMI in, get an HDMI M/M cable of an appropriate length. (Use an online shop for better prices.) This will provide the best picture. (If you have a sound system with HDMI ports, you may be able to go EDBC011 HDMI out to the sound systems HDMI in. Then the sound system HDMI out to the TV HDMI in.) If the TV has a DVI port, get an HDMI to DVI cable (again M/M). For this option, you will also need to connect the audio cable (see below in the composite or component video section).
Alternatively, this Blu-ray player has component and composite video out ports. Note: composite video is limited to SD. For these, you will have to connect the audio cables (RCA l/r audio or digital audio out). The composite video cable is included with the blu-ray player when new. For these, match the colors of the jacks to the wires to make sure that you have them correctly connected. You can put the audio cables to your sound system or your TV, as appropriate for your setup. For some TVs, you may need a RCA audio to 3.5 mm cable (all male ends) or adapter (for example RCA F/F to 3.5 mm M with an RCA audio cable or 3.5 mm F to RCA M/M with a 3.5 mm audio patch cable) . This applies for units with only the PC audio in.
Make the connections with the TV and the video player off (turn off the audio system if you are including that set of wiring). Then turn on the TV and set it to the desired input (use the Input/Source button on your remote or TV). Turn on the audio system (if using one) and blu-ray player.
If you have problems, first try different cables. Try other input connections and try different devices. It's possible for either the TV or the blu-ray player input/output jacks or boards were damaged.
The manual for the EDBC011 is available here: http://www.elementelectronics.com/support_docs/edbco11/edbco11_manual.pdf .
I hope this helps.
Oct 12, 2011 | Element Electronics EDBCO11 Blu-Ray Player
How to connect it to the surroundsystem and the 4 speckers .
Most likely you conneect the MP3 player to the surround system with a 3.5 mm Stereo Plug to RCA cable. The 3.5mm end connects to the MP3 player, and the RCA end to the surround system.
Jul 09, 2011 | DURAGADGET Pure HQ OFC 3.5mm Stereo Jack...
What cable do I get to connect my mp3 player to my sound system ?
You need a cable with the same connector as the ear phones, plug this end into the MP3 player and the other end of the cable connector need to match the stereo input of your sound system.
Jun 28, 2011 | Coby MP-610 MP3 Player
How do you hook up an mp3 player to insignia ns-r2000
You will need an Dual RCA to 3.5mm stereo cable. One similar to this: http://www.dcables.net/Dual-RCA-to-3_5-mm-Stereo-Cable-5-Feet.aspx
It would probably be easier to pick one up at your local Wal-Mart or Radio Shack.
Just connect the RCA connectors to one of the audio line inputs and the 3.5mm to your mp3 player. Set your insignia to receive the source you just connected.
Hope this helps
Apr 07, 2011 | Insignia NS-R2000
Where can I purchase the Audio Video Connection for my dvd player I want to hook it up to my TV but can't find the correct cable Thank you Sandy
For the COBY TF-DVD7500, the video is carried on a single RCA plug cable. You can make due with a composite video cable (with three RCA plugs on each end) or get an RCA cable. The audio output can either be digital audio (which uses a special coax cable) or a headphone connector (analog audio).I believe the headphone jack is a 3.5 mm connector. If you use a composite video cable to your TV, you can connect the red and white plugs to an adapter (3.5 mm M to 2 RCA F). Then the TV speakers will get the audio track; otherwise you can use the DVD player speakers or the digital audio out.
I hope this helps.
Jan 24, 2011 | Coby TF-DVD7500 Portable DVD Player with...
Connect PS2 to Portable DVD Player?
I've done this before, i had to buy double female R.C.A. connectors (3) of them sold individually if I remember correctly, and then proceed to connect the 3 "male" ends from the PS2 cables to the 3 double "female" connectors i bought (best buy, meijer, radio shack, etc.) and then connect the 3 "male" ends of the R.C.A. cables that came supplied with my portable DVD player to the other end of the 3 "female" connectors, and finally connected the other end of the (DVD supplied) cable into the portable DVD player. hope this helps, and i apologize if it sounds a bit confusing, just trying to be as thorough (i have no idea if i spelled that right) as possible. Keep me posted if this helps!
May 31, 2009 | Polaroid PDV 0707N Portable DVD Player
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Lost USB cable for RCA TH1501 MP3
I have the same unit-it already has a usb connector built in on the end,which folds out.The cable just makes it easier to get the unit out of the way-hope this helps!
Jan 14, 2009 | RCA TH1501(1GB) MP3 Player
Help me out
Connect the little end of the USB cable to the top of the unit. If you are looking at the face of the unit, the port for the cable will be on the right. Then connect the big end of the USB cable to your USB port on your PC.
Apr 04, 2008 | RCA H100 MP3 Player
RCA RS2663 Shelf System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
