Question about Sony KP-51HW40 51" Rear Projection Television
Sony kp-51ws500 red haze and red lines across screen
Is there any fix or replace cheaper
  • b-ryan681 Dec 31, 2008
    SCREEN IS ALL RED WITH CURVED LINES OF DARKER RED AND POWER INDICATOR LIGHT IS FLASHING
  • JSMaxwell Jan 04, 2009
    Hello.
    I have used this to successfully get my my green lines to go away. I am now faced with two remaining issues...
    1.)My TV will occasionally (though not as often as before the adjustment) flash green, then turn off and go to standby mode. Do I need to do more adjusting on the green control?
    2.)Since I turned down the green, my reds and blues appear almost florescent. Do I need to adjust them down as well to match? Any tips on setting the colors correctly would be greatly appreciated. I'm not sure about your description of turning down the user control before setting the tubes.
    Thanks.
  • 3 Answers
  • 185 Answers
In side the front grille cover there is a smaller black wooden cover.after removing the grille 2 small screws bottom right and left corners under the caps, remove caps and you will see the screws 1/4 inch driver for these, you will see the cover (wooden) with more screws remove . now about dead centre you will see a little epoxy black box with 6 knobs sticking out from it. don't adjust the top row as these are your focus look clsely at the markings on the box at each knob they say r,g,b 1 for each color, adjust the 1 that matches the color you have too much of red knob for red color etc.
bak the correct 1 counter clockwise untill the lines go away, do this in a darkened room so you can see if there are faint lines still adjust untill they disapear all together the screen will appear in black and white if the user color control is turned all the way down
as it should be for this adjustment when done you can turn the color back to normal. if you have turned this control down too much the tube won't be biased properly and the l.e.d. on tnhe front of the set will blink telling you that it isn't biased properly, readjust untill this doesn't happen amking sure the picture is in black and white (color off) not green and white not blue and white, you get the picture. this is a common problem with these older units.
Posted on Jan 02, 2009
I have a Sony rear projection tv model KP-51WS500. It has had some fine green lines across the screen, but today it has started to fade to green after being on for a few seconds, then truns off. Any...
It sounds like the focus pack needs to be replaced (p/n 122392535) and re-adjusted. The re-adjusting could be the tricky part if you haven't done these before.
Jan 30, 2011 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 tv went red screen on me it has 4 blue lines going across also has blinks 6 times.. what do you think this might be..
Off hand I would con dim the Red and Blue CRT"s. If you were to replace two of them I would also do the Green CRT as well. The cost of just doing two of them is way too expensive in my opinion and you would be better served to replace the set instead of investing the amount of money needed in a 6-8 yr. old set.
Hope this helps,
Skyassoc
Jul 15, 2009 | Sony KP-51WS500 51" Rear Projection...
Red lines across screen
had tv that did the same thing after three years but they were green cost me 300 bucks to get it fixed and the guy said every 3 to 5 expect it
Jul 03, 2009 | Sony KP-51WS500 51" Rear Projection...
Why my screen turning red after minute of use
If the screen looks like the one in the link I posted, then you might want to try fixing it with what is suggested on the site. Keep in mind that this is a band aid fix which compensates for weakening components, however it "should" buy you some time. Don't do these adjustments if this is not the same problem you are having. If the TV shuts itself down, check to see if the blinking code is the same as the one in the web site.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Hope this helps.
Apr 29, 2009 | Sony KP-51WS500 51" Rear Projection...
I have a sony kp-51ws500 that the red is bowed across the screen.
If you are referring to the convergence ICs (STKxxx), then look in the area for fuses and/or low valued resistors that may be open.
Let me know what you find.
Dan
Mar 25, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony projection TV when turned on a solid red line across screen when turned of a flash of red and until the tv is warmed up red ghost letters behind the normal black ones
Hi, you will have to replace the convergence circuit board on this unit. it is failing to calibrate the rgb stream.I'm sensing signal board failure as well.
Mar 08, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP 51WS500 -having faint red lines on the screen. How can I fix it
just checked out a thread on a fix it yourself and im happy to say it worked...I thought mine was really bad. it got to the point where the picture was all red, but it can easily be fixed
here is the link to the how to...dont forget to skip the advert at the beginning.
wife is on cloud 9 right now looks like daddy's goin to get some tonight
this took me less then 10 minutes to fix. once i fixed the red i noticed blue lines also so i adjusted that as well. who ever posted this needs to get an award this is the first time the internet actually was usefull. cheers
Jan 22, 2009 | Sony KP-51WS500 51" Rear Projection...
KP-51WS500
Try this link it has many great reviews. It is very informative for the DIY.
Nov 28, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
217 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
