Question about Kenmore HE2 Plus Front Load Washer
Error code for kenmore elite he2 plus
Please help, I have only had my new washer 9 days and already having an issue with my machine, it will not start after pushing the start button, it will only display a F 01 error code, and after reading the manuel, the trouble shooting section explains a possible fix but, that is not working and I am very upset that I now have to wait three days for a technician to come out to look at the problem and hopefully fix it..... I am very happy with the way it washes the clothes however I am not happy that I am already having problems after 9 days of use! Any info is appreciated! We have a Kenmore HE2 and kept getting an F21 code that was not resolved by cleaning out drain filter and clearing lines. So...we replaced the drain pump assembly ($80+ for part). However, when we try to start a cycle, it will still only continue trying to drain, making a buzzing sound, and after 5 minutes or so it will flash the F21 code (long draining cycle). It acts like it is stuck in drain mode even though there is nothing in the lines or water in the washer. Help! I'm at my wits end.
  • gcalvario Dec 30, 2008
    Please ignore first part of above! I don't know how it got there!
  • 15,935 Answers
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
  • wildcatmom28 Jun 05, 2011
    Thank you, thank you, thank you!!! I can't believe how easy this was. There was SO much **** in my drain filter, I'm surprised the motor didn't burn up!! I recommended this site on FB, thanks again!
  • Tiger12 Jun 12, 2011
    Yup, just got the washer going again- same problem/solution as described in the earlier posts (F21 errror code). Thanks for this site and those who posted the how-to info on checking/cleaning out the water pump filter. It's good to share this easy check/fix. An easy thing for the homeowner to check and should be included in basic troubleshooting pages in the owner's manual.
Our Kenmore HE2 PLUS Flashed F21 we fixed the problem by unscrewing the 4 screws on the toe panel then removing the metal panel.you will find a big round knob on the right bottom inside washer. unscrew it and clean out the part you removed , Then replace it back the was it was and Our problem was solved....By the way sears wanted alot of money to come out to fix this easy problem i'm glad we tried to fix it our self first!!!
Posted on Apr 21, 2011
  • clerougetel Jul 19, 2011
    Thank you so much. Worked like a charm and saved me a small fortune in pointless callout charges!
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
What is a f01 code on my he2 plus front end washer
Hello & Welcome to FixYa
Error Code F01 means that the control is either bad or the wiring harness to the control has some issues. Please check the control board for any bad components as you might need complete replacement of the control. Please get back to me if you have any other questions.
Kevin
Oct 04, 2011 | Kenmore HE2 Plus Front Load Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Flashing F24
All Kenmore appliances are built by other manufacturers, therefore you will need to provide your complete model number in order for us to determine who made your washer. Once we determine this, we can diagnose your error codes for you.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we will attempt to get your washer repaired for you.
We look forward to working with you. Thanks, Ella
Nov 13, 2009 | Kenmore HE2 Plus Front Load Washer
Error code F-28
It may be that the drain pump is not the problem at all. Error Code F-28 on the Kenmore HE2 means that there is a signal error between the Central Control Unit (CCU) and the Motor Control Unit (MCU)
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
There is a tech sheet inside your washer that explains all the error codes. You will have to remove the lower panel under the door to access it. Its usually mounted to the inside of the lower panel on along the interior walls of the cabinet. There will be instructions on how to enter diagnostics mode and a full list of error codes, followed by procedures to follow on how to correct. Also when you take the cover off you will see a white drain that is covered. Turn it counter-clockwise and remove it - but be prepared with towels because this is the lint catcher and there will be water in it. Clean it out and use a flash light to look up the hose area - I found a lot of loose change in mine.
PS Don't tell Sears I told you where they keep their "secret" error code list. Don't you find that irritating? The repairman would have come to your home, opened the washer, and read the tech sheet right in front of you - then charged you for it. Good luck.
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
1,018 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
