Question about Fujitsu 24C1 Air Conditioner
Water coming from inside unit of Fujitsu airconditioner
Water is leaking from the inside of the split system unit, the model number is AST30RBA-W and I cannot find the instruction book
  • Anonymous Jan 24, 2009
    i have the same problem and it isn't addressed in the manual
  • stacey_t Feb 08, 2009
    I also have the same problem... has anyone had any luck resolving this problem?
    Scholar:
  • 140 Answers
Go to http://www.fujitsugeneral.co.nz/scripts/get-manual.pl?manual_id=36 to get the manual. Any questions please ask. Please rate me so I know if I helped.
Posted on Dec 30, 2008
    Problem Solver:
  • 14 Answers
More than likely the condensate drain is blocked i dont know if this model has a condensate pump on it if it does that could also be faulty .you could try pouring water into the unit where the coil is and see does it drain away easily .if not you need to unblock the drain
Posted on Apr 08, 2009
A four year old Fujitsu split system works fine in all modes except the heat mode. Have turned off the main power source for 45 seconds, no change. Can you help please. Model # AST30RBA-W
As stated, sounds like a reversing valve issue, likely need a technician. What exactly happens when in heating? Does it run, still cold, just warm not hot???
Sep 02, 2017 | Fujitsu Heating & Cooling
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
Water dripping from airconditioner inside the house
Water leak is the common issue in split a/cs. Due to coil,air filter, drain pan dust blocked, less rpm of blower motor, short of gas.
If service for the unit is more than 4 months, please do it first. And then check rpm of blower motor, if less replace capacitor.
Check gas pressure. Must be 60 PSI @ 98*F, of ambient temp. If less than that find leak and arrest and do gas charging. Thanks.
Jan 28, 2011 | Fujitsu 24C1 Air Conditioner
The inside unit is leaking water
Water leaking in split unit common, due to air filter & evaporator coil dust blocked- Clean it.
Drain pan and drain hose dust blocked-clean it. And also due to less rpm of indoor motor, there will be forming ice over the coil result to water leaking while defrosting.Replace motor capacitor.
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
Jun 28, 2009 | Fujitsu Heating & Cooling
Leaking water from inside samsung split sytem
if your indoor unit is leaking water down the wall,it is from one of two things.First, is possibly the insulkation on the copper lines is coming loose and the suction line is condesated,with no way to drain,it drips down the unit.The other possiblity is that the drain hose is coming loose from vibration and leaking a little.
Dec 31, 2008 | Heating & Cooling
Fujitsu wall mounted air conditioner.
 during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C)  the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Fujitsu 24C1 Air Conditioner Logo
788 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
