Question about Sennheiser RS 120 Consumer Headphones
I have the rs 120 plugged into power, the green light is on, I have the batteries in the headset, but I get no sound. The switch is on, the RC plugs into the back of the stereo, but no sound. Help, ps I did not get a user's manual, it was a CHristmas gift and was purchased from DAKMART.com
  • s2rdoe10 Jan 12, 2009
    Exactly the same problem.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
http://www.sennheiserusa.com/serviceandsupport_downloadarea_active
You can get the PDF version of the instruction sheets here…
Since you did not go into detail about how you connected the headphones I will make some assumptions
If you plugged the RF connectors into the back of the amp.. make sure to note what that output is.. and that the output is selected on the amp. Then turn the sound on the amplifier up slowly.
The green light indicates you have some type of signal activating the headset.. if you have the headphones plugged into a tape out connection and your amp allows this connection to constantly act as a monitor.. you may be getting enough of a signal to activate the base.. but not enough of a signal to generate audio as that connection is a fixed signal and pretty much unamplified..
When experimenting with outputs on the amp.. remember to turn the amp off when switching connections.. and turn the volume down before turning it back on.. always turn the volume down between selecting outputs ..
Finally verify the headphones work by simply plugging them into a headphone jack..(if you did not get that connector you can pick one up at radio shack) and turning the volume up slowly on the amp..
Good luck
Posted on Jul 07, 2009
I can only get static on my rs 120 head phones
Sennheiser remote/cordless headphones are ordinarily very dependable. From your description it sounds like the problem is with the base unit. Try power-cycling the base with the headphones sitting on the charger cradle (red charging light must be on when you do this) - Unplug the power cord for about 10 or 15 seconds then plug it back in. This action should cause the base and the headset to go through the automatic pairing process. Once the base is paired with the headset, it should begin working again. Check also the channel pushbutton on one of the headphones. Hope this helps!!
Jan 04, 2015 | Sennheiser RS 120 Consumer Headphones
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
Headsets receive no sound
if you have the headphones plugged directly into the audio out, then thats the problem. the audio only supplies a low volume, pre-amplifier output and this needs to be put through an amp of somekind to get a decent volume. Look for a headphone socket on the tv, usually near the s-video plug and coloured green.
May 09, 2010 | Sennheiser RS130 Headset
On my motorokr s9 the green light just stay on even when I don't charge it is there a reset button or anything?
This is caused by a power surge. To correct, plug your headset into charge, and then plug into power strip. Trip the switch on the power strip to off. It will cause a drain and turn off your green light and then allow the headset to turn back on.
May 06, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
Sennheiser RS126 headphones/base stopped working
Broken audio cable entering the transmitter or audio jack plug.
Power supply plug loose / faulty power supply.
Nov 10, 2017 | Sennheiser RS 120 Consumer Headphones
There in no green light on RS 120. There is a red light on indicating that the headphone is being charged. Why I cannot use non-chargeable AAA batteries?
The green light only comes on when it is receiving an audio signal.
Standard batteries will work.. if you NEVER use the charging station.. and plan on replacing them every x number of hours used.. IMPORTANT.. if you forget.. and place the headset on the charging station with standard batteries.. they will probably rupture.. and may well ruin the headset..
If you decide to replace the chargable batteries.. make sure you replace them with the right size and type..
Jan 08, 2009 | Sennheiser RS 120 Consumer Headphones
Green light stays on....headset not turning on
I have had no trouble with mine (3+ months of good use) until today. Same problem you had - green light won't go out, unit won't turn on. Jonsumer's solution got me to thinking, and this worked for me:
1. plug the charger into the wall.
2. plug the headset into the charger.
3. unplug the headset from the wall.
Plugging & unplugging the headset to charger multiple times had NO effect. It was only when I plugged it into the charger and unplugged the charger from the wall that the green light turned off and the headset began to work normally.
Jan 06, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
Headset not working
A modulator is designed for the reverse of what you are trying to use it for. It is meant to be a local TV transmitter i.e. video and audio source INPUT for the TV. It converts A/V to a UHF radio signal that the TV can receive. If the TV has no audio OUTPUTS or headphone jack then headphones cannot be used with this TV. As for the new problem with the TV, I'd like to think this is co-incidental and not your fault. The fantastic thing to do would be to go and buy the lady an LCD TV of a the biggest size you can afford. Most have a headphone socket.
Sep 30, 2007 | Audio Players & Recorders
Sennheiser RS 120 Consumer Headphones Logo
1,516 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
