Question about Watches
Discovery croaking frog clock
I have a Discovery Channel New World Frog wall clock that is supposed to croak every hour. But the chip is broken. Do you know where I can find a replacement chip or a new clock ? thanks Anne
  • katieweb Feb 18, 2009
    I have the exact same clock and I absolutely love it-- but mine broke as well. I tried replacing just the clock mechanism (which I got at ACMoore for 8 bucks) but in the process I destroyed the sound part.:( I have searched the discovery channel website, ebay, the frog shop, and done many web searches but I cannot find anything remotely close to this. I'd love to know if anyone has information about purchasing the entire clock.
  • Laura Henson Sep 14, 2012
    were did you get the clock looking for one
I'm looking for a croaking frog wall clock can you help
Posted on Sep 14, 2012
I have the same problem about the frogs not croaking. Is there any place you can purchase a new clock? I love the clock and miss the frogs!
Posted on Aug 11, 2010
Wrangler Hero Watch analog hands dont work after battery replacement
Remove the PCB and replace the AG4 battery in the analog quartz movement. The stem can be removed by pressing the small lever through the hole visable after the CR2016 battery has been removed. I think it uses a Y121 movement.
Jan 31, 2013 | Watches
Need replacement clock hand
Your best bet is to see if the original manufacture of the clock is still in business. If so, they may still have the necessary information for one of their clock makers to make a new hand for you.
The only other solution is to locate a watch maker who specializes in restoration of old clocks and watches. There are many around who are very good. A new replacement hand can be made for you.
In any case, obtaining a hand will not be cheap. There will be a number of hours of work involved to make a new hand. The watch maker will most likely need the clock movement set to him so he can do the exact measurements required.
As for original parts off the shelf for old clocks, these are not easy to find. Many of these clocks were built on a one-by-one individual basis.
Jerry G.
Dec 04, 2011 | Watches
I have an ultmost model 6695 talking alarm clock. It is supposed to "talk" on the hour and on the alarm. However, it has stopped. The mode has 3 options: time, 12/24 hr, and alarm. I...
Make sure the clock is in the normal clock-display mode, not in a "set" mode. Press the minute key (again, while not in a set-anything mode) and you will see the hourly announcement toggle on and off. The person who designed it that way needs a good kick right in the bracket.
Aug 18, 2011 | Watches
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    Quartz president wall clock, I need to set the chime
    I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
    *Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
    *Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
    If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
    John
    Apr 21, 2010 | Watches
    My new wall clock chimes 2 minutes BEFORE the
    You will need to do a mechanical adjustment to the hand.
    Loosen the hand nut and adjust the hand the tighten.
    Hope this tip helps to solve your problems
    R/
    David
    Mar 19, 2010 | Watches
    Settiongs for Weather Data World Clock
    Citizen Weather Data Clock Settings.
    To set time press and hold for 5sec "set" button
    Use advance to add days, years, hours seconds.
    Press SET to hold.
    Oct 17, 2009 | Citizen Watches
    Lost instructions for Lexon world time clock model Planete
    to set the alarm, press and release the "alarm" button; then press and hold the "set" button until the hour begins to blink. press "adv" until
    the hour AM or PM is correct;now press and release "mode" so that the minutes begin to blink. Set the minutes using "adv"; now press and release "set". Finally,
    press and release "adv" once to bring up (or remove) the alarm icon. Then press"alarm" once to return to the main display.
    To set main display, press and hold "set" until the hour begins to
    blink; press "adv" repeatedly until hour AM or PM is correct. Now
    press "mode" so that the minutes blink, and use "adv" to get the
    minutes right; then press "mode" so that the next item begins to
    blink; use "adv" to advance until it is correct, then press "mode"
    so that the next item blinks, and so forth until you're all done.
    Finally, press and release "set".
    Aug 10, 2009 | Watches
    Adjusting the world time??
    If your watch is Casio:
    http://world.casio.com/wat/download/en/manual/
    If not, give ALL the details.
    Rate, please.
    Mar 30, 2009 | Casio G-Shock 800D 7V watch
    Elgin grandfather clock chimes not working
    I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
    If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
    Mar 29, 2009 | Elgin 0518709FA
    Watches Logo
    847 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
