Question about Whirlpool GEW9250 Electric Dryer
Drying time is 3 cycles.
Just moved my dryer, whirpool gew9250. Not drying like it should. It is now in the middle of the house and is vented thruogh attic and out the soffit. I used flexible foil tubing. Is this why it is taking so long to dry?
  • 242 Answers
Hello , I can help , it was probably moved back to the wall to much or the duct is twisted , get a flashlight without moving the dryer and lean over it and inspect the duct , make sure there are no kinks not even a little one , if the kink/restriction is not there it is somewhere in the duct if your dryer is heating and tumbling. hope this helps , good luck. Phil
Posted on Dec 30, 2008
Maytag Centennial Dryer (MEDC400VW) not drying properly
First of all, please make sure the vent is clear all the way through. Next the vent must be straight as possible. Next it can not be to long. People think that because they feel the air outside the vent is clear, not always true. The vent can be partially clogged. So make sure. Next, if the vent hose has sags or bows and even tight turns. It can accumulate the moisture in it from the drying proceed. If water has collected in the vent hose the clothes will not dry properly. If the vent is to long it can not dry properly either, the blower on the dryer can only move air so far. So the shorter the better. If all of these requirements are meet. Then, I would have to start checking the thermostats. I hope I have helped you. Please respond if you need further assistance.
Jan 29, 2014 | Maytag Dryers
Not enough heat
You may need to adjust the air flow on your dryer vent.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Why would an electric dryer trip the breaker when the dryer vent is disconnected from the duct work but not when it is connected? The dryer was taking sometimes 3 cycles to dry heavy loads.The duct work...
perhaps a safety feature to keep any burning lint from setting your house on fire also check the vent where it comes through the ouside wall of your house they sometimes get clogged with lint and the escaping air cannot vent properly and backs up ,if it is to warm it may tell your dryer sensor clothes are dry when not.I also find an xtra spin or 2 just spins ,not rinses .in washer extracts a lot more moisture out of clothes and they dry even faster
Dec 18, 2009 | Whirlpool GEW9250 Electric Dryer
Admiral Dryer: 5 cycle 3 temperature electric
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Changed motor now dryer works until its too hot
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above).
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer
make sure your washer is spinning out the clothes well..check vent leading out the house,,and make sure the damper or flap is in cgood condition...onthejob
Feb 17, 2009 | Whirlpool GEW9250 Electric Dryer
I have a gas Whirlpool Duet dryer and sometimes the cycle wont complete and the clothes arent dry ( very damp). when i use the timed dry option i ave the same result. last week my washer overflowed and i...
Check your exit vent outside of your house... what you can do is remove vent hose on back of your dryer... run dryer and feel the air coming out of the vent right behind your dryer.. now reinstall your vent line and check outside,,, see if you feel the same or about the same air flow... if your air flow is block, then your heat will not come on regularly to dry clothes... good luck
Jan 19, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer that will not dry well
One of two things... An almost totally blocked vent to the outside or a bad heating element. Remove the vent form the back of the dryer and get a "feel" for how much air flow is coming straight out without any venting connected. Then connect it back up and with the dryer running, go outside and give it the "feel test" judging as close as you can the percentage of air flow loss through the house venting. Anything more the 30% air flow loss will cause the dryer to take forever to dry. As far as the heating element, on a Whirpool, it slides up into a plenum in the back as kind of a rack type assembly. Not that difficult to replace by remove wire connecting to it, thermostats attached to it and (probably) two screws that are securing it in the plenum.
Dec 20, 2008 | Whirlpool Washing Machines
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Clothes don't dry fully on automatic cycle with "normal" selected.
there may be a fault on the low heat setting, check the element works on both settings, otherwise nothing to suggest, apart from are you overloading it with too many items?
Oct 13, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
53 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
