Question about Minolta Maxxum 50 QD 35mm SLR Camera
Mirror lock My 35mm Minolta Film Camera's mirror seems to be locked. I can't depress the shutter button or advance the film. How can I correct this?
3 Suggested Answers
  • 3614 Answers
SOURCE: no shutter/film advance
Try to used a new film..
Let me know again..
Posted on Apr 22, 2008
  • 3037 Answers
Check and see if the mirror is not moving.
The mirror not moving is not the reason your SRT is not working. Mirror flip-up and release is one step of the shutter release sequence that all single len reflex cameras do: the mirror not moving is a symptom that the shutter release sequence was not fully engaged, or is "out-of-sequence".
This problem does happen to older SRT's and is, best case, easy to fix. Two ways this happens: best case, either the advance lever was not fully wound (at the "second to last shot") and by depressing the shutter release button at the shots afterwards you're allowing the camera to bypass starting this sequence: a shop can "trip" your camera to its proper sequencing, but it may happen again because of the second problem described next.
As second-best case, on SRT's the pull-rod in the bottom of the camera (inside the bottom plate) that connects the advance drum Y-lever to its cocking lever becomes "stretched" at the end curl: this is a common weak-link in SRT's. Again, this is a 10 minute fix for a shop (don't do this yourself) to retension this rod and resequence your camera to working order.
Alternatively as a worst case, the mirror lock & release levers or more bottom shutter release mechanisms have become bent, undone or disconnnected. Since this is harder (near impossible in fact) to have this happen by just working the camera, hopefully your problem is not this. Your SRT would be still repairable, but at greater cost.
Call around to find a shop in your area that works and knows what they're doing on OLDER MANUAL Minoltas, then check the value of your SRT in your area and have that shop fix your camera at a cost within its value. Once fixed your SRT is still well within its service life: on SRT's usually only the meter-to-prism glue clouding, cable derailments, internal foam pieces gelling, and that pull-rod give trouble (and all these are still fixable).
Also a simple trick to try to resequence an SRT shutter yourself. If when your shutter release button comes back up (after you wind the camera when pushing down the release button), it seems lower than normal then try pushing in the rewind release button (in its U-depression on the bottom of the camera) and try winding the top advance lever (don't force anything, if this is going to work it should be all free moving). If the shutter release button pops up, the camera should be resequenced. It may take a couple of tries.
If it is not the mirror, then it may be the reason below.
The X-700's have a fairly common issue as they age. There is a capacitor inside, which simply gives out and must be replaced in order for the camera to function. If I remember correctly, it is directly related to the shutter release function.
The replacement capacitor is cheap and the repair can be performed by any reputable camera shop that knows Minoltas. There are even instructions on the web on how to do it yourself. My 700 gave up the ghost too, but I just haven't had the confidence to attempt the repair. I came into another functioning 700, so the repair isn't vital right now.
Please let me know what you want to do and what you find if you check your mirror. I would be glad to further assist you.
Thank you for using Fixya and Good Luck
  • 571 Answers
SOURCE: shutter doesnt work film doesnt advance
Posted on Aug 18, 2009
0 characters
1 Points
My FA camera shutter release button won't work, no reaction when depressed and look through the view finder was dark.
The dark viewfinder usually means that the battery must be replaced as the mirror has fully or partially locked up. A new battery usually fixes this instantly. The stuck shutter release can also be due to a failed battery or is due to the shutter lock being engaged. The lock is disengaged by pulling the film advance lever back slightly.
You can download free instructions for your camera courtesy or the Norman Butkus website; if you find his information useful then consider making a donation as he suggests toward his site running costs.
The battery is either two SR44's or LR44's, the latter are cheaper but give less accurate exposures due to their unstable voltage output, but if you're shooting on negative film instead of transparencies you'll be unlikely to spot the difference. A single CR1/3N battery also does the same job as two LR44's but is harder to find and more expensive than two of the very common LR44's.
Feb 18, 2011 | Nikon FA 35mm SLR Camera
No shutter/film advance
Let me know again..
Apr 22, 2008 | Minolta Maxxum 700si 35mm SLR Camera
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
Nov 03, 2010 | Nikon N80 35mm SLR Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Nikon fm10 cannot get shuuter release button to depress or film advance lever to work. is there a lock on shutter release ?
The film lever is also a switch. If you had advanced the film lever, **** it outward a little. You will feel the detent click somewhat when doing so. Leave the lever outward and see if the shutter will work. The detent is for appling an closed circuit for the light meter. When the lever is fully pushed back in it shuts the power to the meter on off to conserve battery power
Oct 13, 2009 | Nikon FM10 35mm SLR Camera
Loading the N8008 camera
1. Set the film speed manually or DX to do it automatically by holding down the ISO button and turning the command dial.
2. Slide the camera back lock releases toward each other to open the back.
3. Insert the film cartridge on the left.
4. Pull film leader over to the red index mark on the right.
5. Close the back, making sure there's no slack in the film, and the lock releases snapped close.
6. Lightly press the shutter button. The film icon will appear in the LCD panel.
7. Fully depress the shutter button to automatically advance film to frame 1.
You can download a manual from
Mar 23, 2009 | Nikon N8008 AF 35mm SLR Camera
Minolta 35mm X-370 stuck shutter
You are probably on the right track with the batteries. Stick some fresh ones in and the shutter should release. Your may need to use the advance lever to re-**** the shutter and drop the mirror down. You could also try removing the lens and manually pushing the mirror down to see if it stays in the down position.
Mar 16, 2009 | Minolta X-370S 35mm SLR Camera
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
The film won't advance
Look on the shutter release button, there is a lock switch on bottom of the button. turn it toward the prism.
Jul 08, 2008 | Ricoh KR-5 SUPER II 35mm SLR Camera
with electronic cameras, it is the control circuitry. send it for service. your service agent probably will replace the complete pcb as they don't know or wouldn't care to diagnose which minor component went wrong.
Nov 15, 2007 | Contax ST 35mm SLR Camera
Minolta Maxxum 50 QD 35mm SLR Camera Logo
19 people viewed this question
Top Minolta 35mm SLR Cameras Experts
Mark Schmit
Mark Schmit
Are you a Minolta 35mm SLR Camera Expert? Answer questions, earn points and help others
