Question about Kitchen Ranges
Kenmore range... oven stopped working after a "pop" sound fron behind the stove... the clock/timer/oven control panel is dead... the stovetop elements do work though
  • msmelika_15 Apr 13, 2009
    I was using the oven and while it was baking it made a loud pop from behind the stove and stopped working but the top stove is working fine. The oven warms but doesn't heat or bake.
  • Anonymous May 11, 2009
    i was preheating oven and a pop went off,oven died and panel does not work,timer,clock'however top of stove does tried to reset breaker still does not work
    w
    hat is it???????this is a kenmore only about 5 yrs old
2 Suggested Answers
SOURCE: Kenmore oven stopped working and clock/timer is dead
Try and knock off the oven , leave it for about 10-20 minutes then turn it back on , if its still the same go to the manufacturer or where you bought it... Hope i helped
Posted on Dec 30, 2008
Using oven and there was a pop and it went dead...oven, stovetop burner, clock panel, oven light!
Your element has burnt out. Reset the breaker, and get a new element. You can usually see where it has gone.
Some older stoves have glass fuses hidden behind the front panel.
Apr 16, 2016 | Kitchen Ranges
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
Kenmore oven 7 broiler dont work but stovetop does
Check you fuses in the stove top . usually behind the clock area.
Mar 29, 2015 | Kenmore Kitchen Ranges
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 12, 2009 | Kenmore 99123 Electric Kitchen Range
Dec 30, 2008 | Kitchen Ranges
Kenmore range control panel not working
sounds like the control board blew on you replace it.
Dec 16, 2008 | Kitchen Ranges
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
Kitchen Ranges Logo
516 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
