Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Not filling water not rinsing
I have HOBART HX40 commercial dishwasher, when I start to fill it with water, it is not filling with water itself, later I filled water in it but having a different sound at the very end but not rinsing the dishes, the temprature of the lower guage became down after the opeeration. is there any possible solution?
  • 3 Answers
Call 828-484-9562
Posted on Mar 06, 2009
My hobart underbench dishwsaher will not fill or heat
Sound like the inlet water valve is out. So with no water it doesn't sense water to heat.
Nov 30, 2014 | Hobart Dishwashers
How Do I fill the dishwasher with water to first start it
Close the front access door and turn on the power switch. It should automatically fill.
Oct 02, 2014 | Hobart C44a Commercial Dishwasher
Hobart lx30h leaking from bottom
This is a testing for the post on this web site, not a solution.
Mar 27, 2014 | Hobart Lx30h Commercial Dishwasher
Hobart dishwasher LXIH starts filling and stops after 5 seconds or so
Hobart is probably the most user friendly manufacturer out there. Their service manuals are great. Try this.... Good luck Manuals Support
Feb 17, 2014 | Hobart Dishwashers
Hobart dishwasher leaking as it rinses/fills
If the brand is Watts, a rebuild kit is available from Hobart. Their part # 118270. It should contain the float with a red rubber gasket and a bonnet o-ring. Unscrew the cap, clean off the sealing surface and drop in the new float OR you might find a local Watts distributor and see if they carry the kit. That should solve the leaking issue. Let me know.
Oct 29, 2009 | Hobart AM14C-155 Dishwasher
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX15H indicates E4 and will not fill.
This is what I found in the manual...and on a couple of other sites....
OFF-ON procedure.
5. Delime machine.
If this doesn't help let me know and I will get to the bottom of it....good luck and thanks for rating my effort...The Fang.
Apr 27, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart glasswasher: it fills but then nothing
Did you solve your problem?It takes 8 minutes to fill.I'm a hobart tech,let me know.
Apr 11, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Feb 15, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Randomly Fills Up & Spills Over
If your unit fills with the power OFF, 99% of the time it is a bad fill solenoid, OR DEBRIS in the solenoid. But before replacing it, I recommend inspecting it.
The fill valve is in the front area behind the kick panel. It has a large brass cap with little notches on it. Turn off the water and inspect the valve for debris. If you take it apart slowly, and catch the plunger and spring, it is easy. The only trick is having a pair of channel locks big enough to remove the cap!
Good luck. Mike
Jun 09, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
661 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
