Washing machine door
New machine not used as yet tried to use but display show door open although door is closed Display code shows LE on brand new start up. How do you bypass or start this one ?
  • 1 more comment
  • scooter1962 Dec 31, 2008
    The make is a Daewoo Front Load, brand new from Future Shop, model DWD-WD32WS. Seems like the sensor on the front door is maladjusted and thinks the door is still open.
    Scott
  • Anonymous Mar 29, 2009
    I bought the same model from Future Shop over the Web. It got the same problem first day arrived at my home. Temporary remedy is to open the door and close it again. The "Door-locked" light will lit and machine will become operational.
  • Duane Grant
    Duane Grant May 11, 2010
    what make, what model.
  • 15,935 Answers
LE indicates a fault with the motor on the appliance.
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
How to reverse door on a Daewoo DWD-WD32WS
Posted on Apr 23, 2011
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Error code F26
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Erorr code -Err 1 is showing on our machine. Any ideas? Thanks.
Is this a Haier Washing Machine?
'coz I found an answer on their site..
"Q. The display shows Err 1. A. The door is open or not properly locked shut. Open and close the door, or firmly push the door shut until you hear a 'click'. If the problem continues, call the customer help desk or an approved service engineer."
Src: http://www.haier-uk.co.uk/support/faq
Hope this helps.. :)
Jun 09, 2011 | Washing Machines
Washer says f26 and won`t spin the clothes out. is there anything i can do?
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
my daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
Oct 06, 2010 | Daewoo Washing Machines
Code LL flashing. Will not complete a cycle.
The LL error code is not documented very well.
Can you tell me what point of the Wash Cycle the Cycle Status LED is in when you error out with the LL error code?
I believe it will be in the Spin Cycle of the wash cycle.
You could try a Quick Spin test and see if the wash basket will spin up to 850 RPM with no laundry in the Wash Basket. See Page 14 of the Service Manual and see if the Wash Basket will spin up to 850 RPM.
You could also check the TDS for proper range of motion using the SM or this typed out process.
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you fail this test it would be time to remove the machine front cover check if the TDS sensor has fallen of its mounting position between the Tub and the washer frame.
Jul 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
LE message, will not lock the door - Daewoo front load
Hello there:
This is a fairly common problem with these newer machines Here are the 2 most common fault codes on these machines I have listed below this post.
If the machine is still under warranty i would suggest using it normally they will repair this for free
and some of these have a recall on these machines
so i would contact the appliance center where you got this from and see if you can get it repaired ok?
"LE " persists in washer display Lid lock failure Replace switch, linkage, lock solenoid or control board. 1E persists in washer display Lid lock failure Replace lid lock switch or control board.
Dec 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool white magic h65 model.what is LE. AFTER
LE error will get displayed when the Lid is opened. Close the Lid and this will get resolved. Similarly you will get FE when the water is not flowing properly into the Machine its a Fill Error.
Nov 05, 2009 | Whirlpool Washing Machines
Cl is showing on display and machine wont work
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Feb 26, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
198 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
