Question about Pioneer NS-DV88 System
I have a problem with my Samsung HT-DL200P; it won't play DVDs
The DVDs won't play and I tried to clean the lens and the video on the same cleaning disc played without a problem... What's wrong with this machine ??? Thank You in advance for Your answer...
Katherine T. Nowacki
  • loggerlen Jan 07, 2009
    i have same problem with my pioneer htz-55dv
SOURCE: I burnt a video to a DVD+R DL but not playing on my DVD player?
Hi Tim,
Thank you for the tip and I'll try this tonight. Before I left home this morning I am currently re-burning it to DVD-R 8.5GB (it took 5 hrs to burn).
I will try DVD shrink method.
Posted on Dec 08, 2008
  • 624 Answers
SOURCE: pioneer xv htd520 won't play dvds
This is a common problem for this model. It has a memory IC that must be replaced. This is a surface mounted IC that requires exceptional soldering skills to replace. I work at an authorized Pioneer service center and have repaired a good number of these for this exact problem. Unless you have great soldering skills it is not something that should be attempted to do yourself, it can cause permanent damage to the board if not done perfectly.
If you have the proper skills and soldering equipment I will be happy to give you the Pioneer part number so you can replace it yourself. If not, then you really should just take it to a service center and have a professional do this.
Let me know if you would like that part number.
Posted on Dec 12, 2008
SOURCE: It wont play dvds or any kind of video
i want to play dvd or see video when i'm driving the car please
Posted on Jan 03, 2009
SOURCE: Pionner DVR-540H-S no longer plays DVD's
good day, true it's not advisable to use disc cleaner for it may also damage or scracth the optic lens inside.Possibly the optic lens of your player is either dirty caust by dust or faulty. but let's do hope it's only dust related and the only thing you can do now is to open and unscrew the upper cover of your player. Get a soft cotton buds, after dismantling the upper cover locate the optic drive lens and clean the lens by wipping it gently in circular direction. then try to play some DVD.
Posted on Feb 01, 2009
  • 24 Answers
Having the car in "park" is not the key. The unit needs to see a 'ground' on the light green wire that attaches to the parking brake. (see manual). You can get around this by installing a toggle switch OR a relay that will user the 'amp remote' wire as the trigger.
Posted on Jun 14, 2009
Everytime i put a disc in it says no disk who do i fix it to play my movies?
If you are lucky all that has happened is that the lens that reads the disc has got dust on it and needs cleaning. You can get a lens cleaning disc or other DVD lens cleaning products from a shop for this. If you are unlucky then a bit of dirt has scratched the lens and it will need replacing.
Dec 05, 2015 | Samsung HT-X40 System
My samsung ht-p10 home theater system displays "No Disc"
..I would assume that you have carefully cleaned the lense and inspected the flexible ribbon cable..try replacing the spindle our case they are not expensive..good luck Elben
Aug 24, 2012 | Samsung HT-P10 Theater System
My samsung ht-x200 wont play dvds or cds it just displays no disc
Have you tried cleaning the laser with a DVD Cleaning Disc or more in depth by removing the top cover and using DVD Cleaning Fluid & QTips.
If you've tried both these without success then I'm affraid that your laser has failed and in most cases even when replacement lasers are available it's not cost effective to replace it.
Jun 20, 2011 | Samsung HT-X200 Theater System
This problem is with my home theater HT-TZ512. The disc sometimes loads, plays for 15-30 minutes, then randomly stops. The picture is still on screen. It looks like I pressed the pause button. When I...
You need to try a DVD Laser Lens Cleaning Disc.
If this doesn't work then you'll need to remove the cover and clean the Laser Lens with some Lens Cleaning Fluid and a QTip. Just use a few drops on the QTip and then wipe over again with a dry one.
If the above fails then its the Laser that's failing which isn't normally cost effective to replace.
A good way to check is if it will still play CDs but not DVDs then its the Laser.
Jun 11, 2011 | Samsung HT-TZ512T Theater System with...
Hi, My Home Cinema Samsung HT-TXQ120 seems not playing double-layer DVDs. The 4GB DVD are played perfectly, while when I try to play 8GB DVDs, the image gets frozen very soon (less than 1 min) and never...
Hi. There is a change in focus by the laser for a dual layer DVD - the laseer has to read through a semi-transmissive layer for that extra information too.
Cleaning your laser lens with a cleaning disc kit may bring it bck to life especially if you smoke... else could be time for a new laser(s)
Jan 19, 2018 | Samsung HT-TXQ120 Home Theater System...
No DVD is playing and says disc error all times. The same DVD plays on my computer. I have tried many DVDs and the same error everytime
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it say disc error.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
May 15, 2010 | Samsung HT-Z310T Theater System
Samsung HT Q20 dvd player saying No DISK
1. Try cleaning the drive laser lens with a CD lens cleaner.
2. You need to check servo parts, spindle motor and pick up flat cable.
3. Clean laser lens manually.
Oct 25, 2009 | Samsung HT-Q20 Theater System
You could try cleaning the drive with a dvd cleaner disk and also a can of compressed air to blow into the drawer. It may just be dirty. Good luck! I hope this helps you.
Aug 27, 2009 | Samsung HT-P10 Theater System
Disc Error
I reccomend going to radioshack and grabbing one of their dvd/cdplayer lens cleaning kits. This should hopefully clean your lens and fix the problem. If it dosen't I'd reccomend contacting samsung and look into the possibility of sending it in for repair:
May 24, 2009 | Samsung HT-X40 System
Dvd does not load
clean the lens of your dvd if that does not work there is a strip connected to the lens have that replace or adjusted by a tech.good luck.
Apr 03, 2007 | Samsung HT-DS1000 System
Pioneer NS-DV88 System Logo
129 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
