Question about GE DVMRe-Pro
Archive device not ready? error message
I am getting an error message when i go to burn a video onto the dvd. I press the burn button and it says "Archive device not ready." Does anyone know what this error message means and how i can fix it? Any help is very much appreciated Craig
0 characters
1 Points
Disk won't eject Error message: System error is detected System error is detected BE file:\Dvdv_util.c, line:264 Sensecode( 3: 2: 0), Detail:0x0
When operating, errors happen. Turn off the device.
(To turn off, press and hold the power button on the front
of the device for 10 seconds.)
After turning off, press the Open button and remove the
disc from the device
If needed reset the device to its factory settings after the disc is ejected. To reset it to factory settings:
Press the [UP] and [DOWN] buttons on
your DVD recorder simultaneously
when the power is on. All settings
including the password will revert to
the factory settings. Do not use this
unless absolutely necessary.
(Note that this function is possible only
when no disc is inserted.)
Jun 04, 2011 | Samsung DVD-R130 DVD Recorder
Trying to dubb video from hard drive to dvd-r and error 14 keeps coming up on the screen. thanks sylvie
Well, by now I'm sure that you know to clear the code, you press the "Display" button a few times. As for getting the Toshiba to actually burn a DVD, I'm not certain that I can help you there, as I've run into problems burning stuff. Unfortunately, it doesn't burn all the time, even if you use the same routine as the last successful burn.
Sep 26, 2009 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
DVD will not eject
Power off the unit, if it will not power off, unplug the unit for a few minutes, then plug back in.
press the power button (turning it on). Before it can attempt to read the disc, eject it.
Feb 16, 2009 | JVC HR-XVC27U DVD Player/VCR
No picture
you have prbly changed the output of your device change the ports in the back(you might need to use a diff type of cable), or on the remote press the display button
May 28, 2008 | Cyberhome CH-DVD 300 DVD Player
I am trying to burn a dvd which come up not enough space on the disk. Could you please advise how I can compress the information to copy onto one disk. I have a Liteon 20X writer.
Depends what file types you'd like to compress. You can try compressing them the with Winrar or Winzip into an archive but if you're talking about videos, mp3 or photos than it is highly unlikely that Winrar or Winzip can help you unless you're talking about small lack of space.
Apr 10, 2008 | DVD & Blu-Ray Players
DVD will not finalize
Bad Disk batch is the most common problem if it is occuring with the same batch of dvds. Other problems could include that you need to get a firmware upgrade for higher speed discs. If you are using a disc that burns faster than the current speed of the machine you need to download the upgrade (follow the directions that are given in most dvd blank packs) and insert the CD that you downlaoded the program onto into the DVD player/recorder.
Feb 09, 2008 | Zenith XBR716
Philips DVDR3450H
Put the DVD back into the drive...Then open the DVD menu by selecting the first tittle on the disc....Hold down the up arrow on the remote to make the "Editing menu" appear....Then select "Finalize Disc".
These instructions can be found on page 54 of the instruction book.
Dec 29, 2007 | Philips DVDR3450H DVD Recorder/HDD...
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Emerson DVd with Video Cassette Recorder EWR20V5
Try using 8x and lower DVDs and -R ones; try cleaning with CD cleaning disk and then try recording a few min again. If that doesn't help try unplugging and waiting about 30min then put in disk that was previously recorded and go to last item and play it to end (if 2hr long skip to last skip and then play until it finishes) - now try just recording a few min using the manual DVD record button and see if error comes up again - usually this unplugging somehow resets everything. Hope this helps ya'll.
Oct 25, 2006 | Emerson EWR20V4 DVD Recorder/VCR
GE DVMRe-Pro Logo
169 people viewed this question
Top GE DVD & Blu-Ray Players Experts
ray gallant
Vladimir Frolov
Are you a GE DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
