I refilled an original HP Ink all seemed fine and no error messages. When I came to print a page instead of what I wanted the printer just printed one or two lines of Smiley faces and some symbols of plain cards, hearts,Clubs, etc. The was also some short text " HP - PCL XL ;2;0;Comment copyright samsung Electronics Co Ltd. I have completed a reset, switched off and on, put the Ink in and out but nothing seem to work! Can anyone Please help!
SOURCE: black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
SOURCE: HP 1300 randomly printing pages with tiny smiley faces and square
Try reinstalling your drivers. The computer may be confused with two different sets because of your second printer. If that doesn't work, and you have another computer available, hook the printer up to that one and install the drivers and see if the problem persists. If it does, then I really don't know what you can do, because that means the problem is in the printer's internal control and would be very hard to fix. If it doesn't persist on the second computer, then you know it's the first computer that's causing it. If nothing else works, try running a scan for viruses and spyware because they too could be interfering with your printer drivers. The computer actually does communicate with the printer even when you're not printing anything. It basically checks to make sure it's still there and waits for a response back with the printer status, etc. Some other program (whether wanted or unwanted) could be interfering.
SOURCE: HP Colorlaser CP2025dn PCL XL error Subsystem:
This seems like a driver issue to me. Are you using the Universal, PCL5 or 6, or PS driver?
If using PCL and are getting this error, try the Universal HP driver from the website. Likewise, if you are using the universal, try the PCL6 device specific driver.
If this fails, let me know and I can assist further
SOURCE: Incompatable Ink Cartridge HP C4480
Cartridge failed try another new one.
Yea it is new and should be good but they are machines and are prone to failure too.
SOURCE: Printing problem with HP laserjet 1320
I've seen this error on this model in the past. I was only able to resolve the issue by replacing the formatter board. Hope this helps.
Thanks for suggestion, I downloaded PCL6 and Universal drivers and it still prints out the same two line message..
