Question about Dell E153FP 15" LCD Monitor
Monitor won't display.
A circuit breaker popped, and when reset the PC started fine, but the monitor didn't. It's a 15 inch flat panel. The power light will blink from orange to green, and there will be a momentary flicker on the screen (it's too quick to tell if there is any content or if it's plain white) each time the light changes from orange to green. It behaves as if it's in sleep mode, but nothing I do will wake the monitor. It does this regardless of which PC it's attached to and other monitors work fine on the PC. We had surge protection on both pc and monitor. Is there a way to reset the monitor? It's a Dell E153PC 15 inch TFT LCD Flat Panel. There are four buttons on the front of the monitor, one is the menu, one has a plus sign, one has a minus sign, and the fourth is the power button. I have discovered that if I hold the minus sign button down, the power light will change to just orange and stay that way unless I disconnect power then it will return to the blinking state. I also cannot shut the monitor off with the power button. I've tried holding buttons down when I connect power, in all combinations, to no avail, I set up a computer to go into sleep mode, connected the monitor, then woke up the computer with no luck, I placed a PC in hibernation, connected the monitor, woke up the PC, and no luck there either. Is there something I'm missing? I've swapped out the cable with one that I know works and that didn't help, I've replaced the power cable (I know, but I'm desperate) and that didn't help either. Any further ideas would be most welcome.
  • 1 more comment
  • Kim Poole Jul 30, 2007
    I've got it! There was a blown capacitor inside the monitor. I found a local TV repair shop that put in a new one for $5, and the monitor is working great. Thanks for the help.
  • ajv75 Apr 14, 2008
    I have a Dell E152 FPb monitor that is doing the same thing. Works fine as long as it is stays on. If the computer goes into sleep or hibernation mode, the monitor will not come back on
    when I try to wake it up. Power light blinks (green, orange, off,
    green, orange, etc.) and then the screen blinks with dark lines and
    eventually goes off. Pressing the power button does not do anything.
    Only way I've gotten it to work again is to unplug the power cord in
    the back of monitor. Updated Video driver, but same problem happens again after hibernation or sleep mode. Any idea?
  • Anonymous May 05, 2008
    monitor comes on and then goes black
  • Dell Master
  • 12,061 Answers
I would suggest that the "Event" that caused the CB to trip has caused ya Monitor to fail.. Probably in the Power Supply, My "Pet" area... lol.. anyway Thats wat I would think. It may even have an internal "Fuse" that has "Blown"?
Posted on Jul 30, 2007
Trips breaker
tripping breaker indicates over load or dead short
it could be from failed start /run capacitors on the compressor unit ( (most likely)or from vermin across the power board
I suggest that you have a technician inspect and quote on repairs
Jul 18, 2015 | Heating & Cooling
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Loud pop while fixing a light and now the light wont go back on
More than likely tripped the circuit breaker for that circuit in the main breaker panel. I would check they should be labled for which one controls the lights for that room. Just turn it off and back on to reset the breaker switch.
Dec 16, 2012 | Televison & Video
My amana fridge keeps blowing the GFI circuit
change the GFI circuit to 20 amp
Mar 30, 2017 | Refrigerators
Dishwasher control panel unresponsive
OK I am not an expert but I have spent the last two weeks learning about and fixing my dishwasher! Hopefully I can save you a headache. Try the following:
* Flip the switch off and on in your breaker/circuit box for 10-15 minutes. May reset your washer.
* If that doesn't work, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If normal function still does not resume after that, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit or toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If everything looks good but that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
There may be some additional instructions specific to your model hidden in an envelope behind the kickplate of your washer.
Hopefully some of that helps!
Apr 18, 2012 | Maytag MDB7609AWS Builtin Dishwasher
Machien wont start, fill up or anything please help
just had same problem, washer was working and when new load was started it would not start. circuit breaker popped and reset it. no lights on panel and circuit breaker good in house. pulled power panel off and opened circuit card and notice black burn spots between cards which looks like the control panel is fried now. Cost about 200 to order, not knowing other costs if repairman fixes it.
Oct 02, 2010 | Washing Machines
My Dell? E198WFP Flat Panel Monitor the gree ligth on the power botton not working
green light on means your monitor showing display.change your button .your monitor working properly.
Jan 15, 2010 | Dell VOSTRO SLIM TOWER and , MONITOR 19...
HOW TO OPEN THE DELL MONITOR # 153FP BACK PANEL TO CHANGE THE BULB?
You have to remove the stand and use very thin flat balde screw driver to pop the front and the back panel apart starting at the bottom pf the unit. Are you sure that the back light lamps are bad? More likely to be the inverter circuits of bad capacitors in the power supply which is more likely, and if it does have bad caps, it will usually take out the transistors in the inverter circuit with it.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 04, 2009 | Dell E153FP 15" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
552 people viewed this question
Clive
Clive
Alun Cox
