Computer does not read flash drive
I inserted the flash drive in the computer, and it acts like it doesn't read it. (I WAS USING MY COMPUTER EARLIER AND IT SHUT DOWN WITHOUT EJECTING THE FLASHDRIVE, AND AFTER THAT THE FLASHDRIVE FALL INTO THE GROUND) it is not wet or anything. How can I solve this matter, too much information inside
  • Hiddy Feb 24, 2009
    When I put the flash in the USB slot, the computer does not read it. I tried it on my laptop as well, same probplem.
  • Anonymous Apr 04, 2009
    my laptop doesn't read any of usb flash drives..also it hangs whenever i connect one to it..??
    and then i have to go for emergency shut down..
    pls help..
I had the same issue occur so I went to My Computer screen, right click in empty space and click on properties. Then click on the harware tab, and click on first box labeled, device manager. After you click there look through the list to where your port is at and if ther is a yellow caution sign, click for it to reinstall driver and see if that works, it worked for my issue. Good Luck
Posted on Apr 11, 2009
Delstar ds 4327
Posted on Jan 02, 2009
Why won't Xbox update?
To resolve this problem, try the following solutions.
Solution 1: Check your Xbox Live connection
If you're having problems connecting or staying connected to Xbox Live, see I get an error message when I test my Xbox Live connection.
If you still experience the problem, try the next solution.
Solution 2: Clear the system cache
Removing the temporary files on your console might solve the problem. Follow the instructions at How to clear your Xbox 360 system cache. Then, try downloading the update again.
Solution 3: Copy the update to a USB flash drive, CD or DVD
Copy the console update from your computer to a USB flash drive, CD or DVD, and then install the update on your console. Here's how:
Copy to a USB flash drive
Note The USB flash drive must use the FAT32 file system.
  1. Plug your USB flash drive into a USB port on your computer.
  2. Download the update file.
  3. Click Save to save the console update .zip file to your computer.
  4. Unzip the file:
  • If you are using Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
  • If you are using an earlier version of Windows, you need to use a special software program to unzip the file (for example, WinZip).
  1. Copy the contents of the .zip file to the root directory of your USB flash drive.
  2. Unplug the USB flash drive from your computer.
  3. Plug the USB flash drive into a USB port on your Xbox 360 console.
  4. Restart the console.
  5. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Burn to CD or DVD
You can also download the update to your computer, burn the update to a CD or DVD, and then install the update on your console. Here's how:
  1. On your computer, download the update file.
  2. Click Save to save the console update .zip file to your computer.
  3. Unzip the file:
  1. Insert a blank, writeable CD or DVD into your computer.
  2. Copy the contents of the .zip file to the root directory on your CD or DVD, and choose to write (burn) the files to the disc.
  3. Once the files have been burned to disc, remove that disc from your computer and insert it into the disc drive on your Xbox 360 console.
Dec 15, 2013 | Microsoft Xbox 360 Console
I plug my zeepad into my comp with a usb plug it tells me it's looking for software to download but some other screen pops up asken me to put in the software disk that came with my device but I never...
Same problem happens to me when I insert something into one of my computer's USB ports, such as a flash drive, it doesn't get recognized. This happens with things other than just a flash drive as well, like my iPod. I have numerous USB ports on my computer, but they all act the same. I'll insert a flash drive and even after it's not automatically recognized, I'll go into "My Computer" and it shows all the "Removable Disk" drives as being empty. I'll click on one and a prompt will come up and say, "Please insert a disk into drive F" or whatever drive I happen to click on. I've tried this with all the drives but to no avail.
http://mhelpdesk.com/field-service-management-software/
Oct 06, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
Acer Aspire 5742Z-4457 windows 7, I changed hard drive and can't get it to complete software Installation. what am I doing wrong? how can I get hard drive installation instructions.
Hi Keith Sr,
You can easily install the Windows 7 in your computer after checking and ensuring the system requirements. You can insert the Original Windows 7 OS in your drive and reboot your notebook; this will make your notebook boot from the DVD. Follow the installation wizard and after the installation, enter the product key and then register the product at the Microsoft website.
For additional information please follow the steps below.
1. Hook up the hard drive, then insert the install DVD, and boot from the DVD to start the installation.
2. Boot your computer using the Windows 7 installation disc or USB flash drive. Turn on your computer, insert the Windows 7 installation disc or USB flash drive, and then shut down your computer.
3. Restart your computer and then keep on tapping the F12 to enter the boot menu.
4. Refer to on screen instructions to select either CDROM/DVDROM or USB CDROM.
5. Press any key when prompted, and then follow the instructions that appear.
6. On the Install Windows page, enter your language and other preferences, and then click Next .
-If the Install Windows page doesn't appear, please repeat step 3.
7. Once your on the Please read the license terms page, click I accept the license terms , and then click Next .
8. On the Which type of installation do you want? page, click Custom .
9. On the Where do you want to install Windows ? page, choose the partition that you want to install Windows 7 on, or click Unallocated Space if no partitions are listed, and then click Next .
10. If a dialog box appears saying that Windows might create additional partitions for system files, or that the partition you chose might contain recovery files or other types of files from your computer manufacturer, click OK .
11. Follow the instructions to finish installing Windows 7 , which include naming your computer and setting up an initial user account.
Hope it helps.
Thank you for using FixYa.
Jan 04, 2012 | Computers & Internet
I changed the hard drive in my ACER Aspire 5742Z-4459 and followed directions installing the recovery disks but when it down loads it can not go past #29 of 42 in software installion. It says installing...
Hi Keith,
Hope it helps.
Flash drive doesn t work
if the flash drive doesn't recognize try to insert it to other device or computer to test the condition of your flash drive if bad change it..
Jan 03, 2012 | LG Televison & Video
I just purchased a StoreJet 2M 320 GB drive. I would like to format it for use with my iMac. The MAC software doesn't seem to have a solution. How do I format the drive?
When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it using a computer with Windows OS. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy. You need to format the flash or external drive. Format thedrive as primary drive and in FAT32. (FAT32 will allow data to be exchangedbetween MACs and PCs also between XP/Vista and earlier versions of Windows).
Jul 06, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
My flash disc is unrecognized by the pc
Try inserting it into a different USB port, or try one on a different computer. If that doesn't work, you'll have to resort to formatting the disk to continue using this flash drive. (Formatting deletes all the data on the disk though).
May 04, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do I use my flash drive?
hello
make sure your system supports and has USB 2.0 software driver to facilitate the flash drive
lal you have to do then, if your pC supports USB 2.0 , is to insert the flash drive into any of the USB ports on your computer . The flash drive behaves and acts as a portable hard disk drive . You can drag and drop imnages, files, data, videos, etc.. from your computer to your flash drive -- or from your flash drive to your compauter -- all very simnple
Oct 27, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
The door on my read write drive won't open but I was just using it earlier and all was fine
Try opening the drive with the emergency exit, there is a small hole next to the eject button, insert a pin or needle to open the tray with that, in most cases the drive tends to act like this after 2-3 years of use. not an error with the drive but the belt on the motor that opens the tray gets loose.
Nov 14, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
I reformat the flash drve and i plug it in my laptop my laptop
Hello, Is it on any computer that your flash drive cannot be read?
Try putting the USB flash drive into a different slot USB on your computer.
There could be a number of reasons for this problem.
Here's a related article that might help: http://ask-leo.com/why_wont_my_system_recognize_my_usb_device.html
Nov 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
1,104 people viewed this question
 Grubhead
Grubhead
