Question about Microsoft Xbox 360 Console
Red light on lower right
I get one light on lower right then codes E 79
i check removeable hard drive that is ok
  • jt44 Dec 31, 2008
    red ring on lower right with E74 code. screen says "system error".
  • 142 Answers
The console needs to be repaired, something within the console has failed and the console is no longer in working condition. Call xbox tech support and they can set up a repair.
Posted on Dec 30, 2008
79 lincoln continental radio wires
This is for an 82. Hope it helps.
Constant 12V+Light Green Switched 12V+Yellow/Black Groundn/a IlluminationBlue/Brown Dimmern/a Antenna TriggerOrange/Blue AntennaRight Rear Front Speakers5 1/4" DoorsLeft Front (+)Green Left Front (-)Black/White Right Front (+)White/Red Right Front (-)Black/White Rear Speakers6" x 9" Rear DeckLeft Rear (+)Pink/Red Left Rear (-)Pink/Blue Right Rear (+)Pink/Light Blue Right Rear (-)Green/Red
Jun 18, 2013 | Cars & Trucks
Xbox-360 elite lower right hand red flashing led light code error E73
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 17, 2011 | Microsoft Xbox 360 Console
Someone plugged there xbox 360 HDMI cable into the USB port in a laptop. Now they get a E74 and 1 red light lower right side . What can they do now.
Jan 14, 2011 | Microsoft Xbox 360 Console
My xbox 360 has one red light and an error code: E 79
That error code means that your XBOX had trouble reading a file from the hard drive. Your hard drive could be failing, or it could some of the files could have become corrupted. Try playing the XBOX without the hard drive to see if the error reappears.
Try to reconnect the Hard drive and see if it still errors. If it does, get a new hard drive.
Nov 13, 2009 | Microsoft Xbox 360 Console
Red light flashing on ps3.not over heated as only switched on for 2 minytes if that
OK - the problem could be with the hard drive connection - I have had the same problem after having moved the PS3 from one place to another. Apparently the same falshing red light fault indication is caused by either a poor hard drive connection or damaged hard drive.
Disconnect the powewr, remove the hard drive cover on the left hand side of the PS3, remove the blue screw (philips head), lift the metal latch and move to the right, the hard drive will disconnet and can be withdrawn from the unit.
Put it back in (carefully!) and slide it to the left, there is enough space on the left side of the drive to either slip in a finger or screw driver and ensure it is fully home.
Lower the metal clip back into place, replace the blue screw and cover and it should now boot up when powered on - if it doesn't, try the same procedure a couple of times - if this still doesn't clear the problem, it could be a faulty drive.
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
One red light on xbox 360
One red light means either the hard drive isn't connected properly, or the video cable isn't connected properly, or is damaged.
Check the hard drive, and the video connection to ensure they're in there tight.
Mar 17, 2009 | Microsoft Xbox 360 Console
Xbox 360 - E 79 error code
1-800-4MY-Xbox
This is the # for Microsoft
Repair is prepaid and is free -if the warranty is still good-
The will tell you how long the xbox will be gone usually 1-2 weeks
They will give you xbox.com code to track the xbox
UPS code to track its progress and where it is at.
Hope this helps
Please rate my help//
Nov 28, 2008 | Microsoft Xbox 360 Console
1 red light on 360
Make sure that all of the pins for the harddrive are lined up properly, and make sure that they aren't bent at all. If that doesn't work, it may just be a faulty drive, in which case you will probably have to replace it(the hard drive).
Mar 15, 2008 | Microsoft Xbox 360 Console
Red rings of death
E79: Hard Drive Error. It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and re-attach it.
Check here for more thing to try
Nov 04, 2007 | Microsoft Xbox 360 Console
360 errors
Check for more solutions here
Microsoft Xbox 360 Console Logo
19 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
