Question about Zebra LP 2844 Thermal Printer
Zebra Lp 2844-Z printer flashing green and red alternately?
I have a Zebra LP 284-Z label printer. The LED flashing green and red alternately. It means the FLASH memory is not programmed. It was working fine yesterday. I do not know how the memory got lost. I called
Zebra tech support. They told me they never see this kind problem. And He is doing research on it. It has no removable memory on the board. Everything is soldered on the board. Please help.
Thank you.
Marser.
  • 1 more comment
  • Angelo Wang Jan 05, 2009
    Thank you for trying. I am waiting for Solution # 2 now.
    Solution # 1 does not work before The computer cannot "TALK" to the printer while the LED is flashing on Red and Green.
    Happy New Year to all.
    Marser
  • np19 Feb 19, 2009
    The power to a 2844 was accidently removed due to a pure connection. When turned on only solid orange. We removed cover to check – now it flashes red and green. Could I be the same problem?
  • ballwegm Mar 24, 2009
    Does not print my inventory labels, only a random series of letters and numbers on many labels.
-Install ZDownloader from Zebra's web.- http://www.ups.zebra.com/ctp/upgrade.aspx visit this page and do nothing to use in step 3 part to download for your stable firmware, only find and download it
-Turn off printer and get ready on Zdownloader sofware-You could see easly "Auto Detect Printers" on ZDownloader, press and hold the label feed button and keep your finger in there then click the "Auto Detect Printers", if you are seeing your printer in list now, continue to keep your finger in feed button-Select the firware.prg file, right click with select your printer in list and click "Download to Selected." -you are still keeping your finger in feed button in this time. You will see the feeding will start and your problem fixed.
Sorry for my english, haven't got enough practice.
Posted on Feb 13, 2012
  • auladali
    auladali Sep 06, 2012
    Hi Nazim Eskikakiz , Thanks for this solution;but I have just a question, have you tested this solution ?
  • 53 Answers
Ballwegm your printer is in line mode and is printing the code instead of the label as it does in page mode. Zebra Lp 2844-Z printer flashing green and red alt - line_mode1.jpgline_mode2.jpg This will return it to page mode Posted by ballwegm on Mar 24, 2009 Does not print my inventory labels, only a random series of letters and numbers on many labels.
Posted on Apr 16, 2009
Sounds like it's in firmware download mode. Try sending firmware to it.
Posted on Jan 05, 2009
Zebra thermal printer 2844 printing double on ups.com. printer preferences set to 1 copy.
hi,
- Turn off the printer.
- open it and check the labels roll.make sure its correctly fixed.
- close the printer.
- press and hold the green button and switch on power.
- release after it starts red light flashing.
- the printer will run a self test.
- turn it off and then on again.
- re-check the settings of the printing software.
- now print.
thank you!
Sep 08, 2011 | Zebra LP 2844 Thermal Printer
2 blank labels are coming out after the correct label
hi dmieze.1.Switch off the printer
2.Remove the labels roll and then load it again
3.Press and hold the green led button and switch on the printer.
4.Release the button after it lights red.The printer will self test.
5.swicth it off and the on and try printing now.
Aug 26, 2011 | Zebra LP 2844 Thermal Printer
My ups thermal printer zebra lp 2844 wont print labels properly
press button until flash 7 times to calibrate, turn off, tur on again if pressist, check the setings from the driver, if thei correct. ajust if necessery.
Jul 05, 2010 | Zebra LP 2844 Thermal Printer
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
How to print configuration page for zebra lp 2844-z
With the printer off, press and hold the FEED key while you turn the printer on. When the LED flashes once, let go and a Config label will print.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Zebra LP 2844 is stalling out on every print.
Maybe the printer is not getting a good calibration on the label. If the status LED is a steady RED when trying to print, then the printer thinks its out of labels. A manual calibrationi could solve that.
1. Turn the printer off
2. press and hold down the FEED key while turning on the printer.
3. keep pressing the key until the status light flashes once, then let go
4. The printer will auto-calibrate for the size of label and then should be ready to use.
Press FEED once after its done and 1 label should feed.
Hope that helps !
Apr 06, 2010 | Zebra LP 2844 Thermal Printer
Zebra 2488-z
Have you tried cleaning the sensor? It is underneath the labels oppoistethe print head.
Oct 18, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 label printer
I'm having the same problem and got the same result when trying the manual calibration on the 1st page...
Jul 14, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
6,831 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
