Question about Gateway 5200XL PC Desktop
Will a DDR Ram work with a DDR2 Video card?
Using a gateway 5200 XL... specs listed here -
want to install a EVGA GeForce 9500 Gt Video card listed here -
my computer has a DDR memory and the EVGA has DDR2. The PCI express port will fit but don't know if the memory being different will affect the computer or not....
on a side note looking to add a another 1 GB of RAM to further boost speed, will it make a huge difference in gameplay such as CoD WaW?
  • thepife121 Dec 30, 2008
    using XP for an OS, currently using 512 mb DDR SDRAM with a 256 video memory,
    the new video card will have 512 mb video memory.
    debating on adding 512 mb RAM and having a total of 1 GB or just buying a 1 GB and having 1.5 GB total RAM
    is adding any ram goign to be worth the price and how much? computer is capable of using up to 4 GB of RAM
    Problem Solver:
  • 19 Answers
The on board memory on the graphics card being DDR2 will NOT affect the system memory being DDR.
And the memory you want to add depends on the memory you have allready installed on your machine and what version of windows you are running.
Please post back with more info on this.
Posted on Dec 30, 2008
  • SoleAngelus Dec 31, 2008
    Yeah it will be worth it, i usually stick with this rule when putting systems together :
    Xp min memory1Gb - Vista min memory 2Gb
    Price of memory can be different depending whch country etc your in and the speed and stepping of said memory, id go for the 1Gb extra memory, as the price difference wont be all that much.
    Also buying online is usually cheaper.
2 Suggested Answers
  • 11 Answers
SOURCE: What is the coprocessor driver and how do I get
Sounds like when you installed Windows 7, you need to update your driver for your Intel Core 2 Quad processor. You can get this from the Intel website.
To answer the first question: A coprocessor is an additional processor that works with the main processing unit to carry out a specific function. The two most common coprocessors are the math coprocessor, used to speed up calculations, and the graphic coprocessor, used to improve the handling of graphics.
Posted on Dec 10, 2009
Hello, I want to know, if the motherboard Asrock K7VT2 can support DDR2 memory.
No, it supports DDR, SDRAM...front side bus speed 266/200 can max out with 2GB's of PC3200...1GB in each slot. I hope this helps.
Aug 06, 2011 | Asrock K7VT2 Motherboard
How to Choose Memory (RAM) for Your Computer
You need memory for your computer. But how should you choose the right kind? Whether you're upgrading your computer or building a new one, learn now.
Step 1 If you bought your computer from a manufacturer, use a search engine or go to the manufacturer's site to find the specs on your model. The max RAM found in the specs is likely the max RAM the whole system supports. To find the largest size module the system supports, divide the max supported RAM by the number of slots. Also listed in the specs should be the max speed supported and DDR type (listed as DDR, DDR2, or DDR3). Alternatively, instead of max speed and DDR type, the specs may list something like PC# ####, where the "#" is some number. This is just a different way of representing speed and DDR type, and works equally well in finding the right RAM. If you know the largest supported module, max supported speed, and DDR type, skip to the Tips and Warnings section.
  • Step 2
    If you're building a new computer, follow the above step, except search for motherboard model specs rather than computer model specs. If you don't know the model, look for it printed on the board.
  • Step 3
    If you couldn't find your computer's specs, the info wasn't detailed enough, or you have a custom-built computer, go to (also in the resources below) and download the freeware SIW. Install and run it. On the left side, under the "Hardware" section, select "Memory."
  • Step 4
    The "Memory Summary" section on the right side shows the maximum amount of memory that can be installed in the system (listed as "Maximum Capacity"), and below that is the number of memory slots (listed as "Memory Slots"). The "Device Locator" sections tell whether or not memory is installed in that slot. To get the largest size module the motherboard supports, divide the "Maximum Capacity" by "Memory Slots." To get the speed and type, look under the "Device Locator" section, for the listing "Memory Type." Write down the PC#-#### part, where "#" is some number. Also for the listing "Speed," write down the value in parenthesis. For example, in 333 MHz (DDR2 667), write down only the (DDR2 667). You now have the largest supported module, RAM speed, and DDR type. You can use either the PC#-#### or the speed and type when searching for RAM.
  • Step 5
  • In Step 4, you found a supported RAM speed, but it may not be the fastest supported. Just to make sure, look to the left side in SIW. Under the "Hardware" section, select "Motherboard." Using this info, go to the manufacturer's site or do a web search, and see if you can find what maximum RAM speed the motherboard supports.
  • Step 6
    If you're building a new computer and need to buy RAM, look up the specs on your motherboard to find out what kind of memory it supports.
  • Step 7
    The RAM you buy should be no larger than the max supported module size, and should match the type and speed supported by the motherboard.
    Open source site for computer pc error fixing software site is on
  • on Jan 08, 2010 | Computers & Internet
    How much RAM can I use in my Medion M3 Composer 5200 PC Desktop?
    Max supported ram available in this PC is 1GB DDR Ram. I will include a link to see the full specifications on your computer.
    This should solve all of your problems :)
    Feb 04, 2011 | Medion M3 Composer 5200 PC Desktop
    I bought sims 3 and *it doesnt work* !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! *i am sooooooo sad* my computer is an xp pc...
    what ae the specs of you computer? sounds to me like it is a minimum requirements problem. if you list the specs ( ie...CPU, Ram (amount and, ddr, ddr2) video card specs. I will tell you if it will play. if you have minimum requirements chances are it is too slow as I had same problem with wifes met minimum but still wouldnt load. also ensure that you have newest video drivers as well as directx installed.
    Nov 04, 2010 | Computers & Internet
    Do dg101ggc support ddr2 ram
    yes it supporst DDR2 ram u can use DDR2 ram with that
    Dec 19, 2009 | Intel D101GGC Motherboard
    What specs should I buy for my cpu that can play latest games like L4d 2, Cod MW2, prototype, etc etc.. and whats the difference between ddr2, ddr3, or gddr 2, gddr3?
    a setup to play these kind of games
    u need
    cpu : core@duo any model
    graphic card : ati hd 3850 or higher /// nvidia 9600gt or higher
    ram : 2gb or high with 800mhz fsb or more
    ddr2 and ddr3 are types of ram
    ddr2 is the most widely used one
    dd3 is the latest model in rams and is the fastest, but is very expensive
    price/performance is better or ddr2
    gddr2, gddr3, gddr5 are different models of ram that is used on graphics card
    gddr5 is the best that is in the market for mainstream users
    Sep 29, 2009 | Computers & Internet
    I have a p1865d7 v2.0 mercury motherboard i want to know whether it can support ddr2 ram or not and what are the processors it can support - here is the info. and answers are u can use any processor wht uses Socket A and u cant use ddr2 because it uses only ddr.
    if this helped rate fixya
    May 11, 2009 | Computers & Internet
    Can i install 1GB ddr2 on P4VMM2 Motherboard? i want to upgrade my pc; board is: can i P4VMM2 Motherboard; cani i use 1GB ddr2 on this and a 512 MB if vid.card?
    Unfortunetly you cannot use ddr2 memory on this motherboard. The motherboard supports only PC2100/PC1600 DDR memory if you have version 8.1 of the motherboard. If you have v5.0 of the motherboard than you can only use sdram or ddr 266Mhz RAM. The same goes for the video card. The p4vmm2 motherboard is a rather old motherboard so I don't think it will payoff to upgrade the computer. It will be probably the best if you buy another computer.
    best regards
    Mar 23, 2009 | EliteGroup P4VMM2 Motherboard
    Ram card
    Hi giovanni2,
    Sorry but you're board does not support DDR2 memory.
    Only 2 x 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR400/333/266). There are two PC Chips M871G.
    One is M871G (V1.5) & the other is M871G (V3.1). Neither support DDR2 memory. DDR2 memory used DIMM slots with 240-pin. The memory slots on you're board uses 184-pin. The board will not function with 240-pin memory.
    PC Chips M871G (V1.5) link.
    PC Chips M871G (V3.1) link.
    If I can help you further, feel free to post.
    Suggestions & comments welcomed.
    May 22, 2008 | PC Chips M871G Motherboard
    Graphics card upgrade
    Not compatable at all.
    DDR SDRAM memory uses 184 Pin Dimms
    Double-Data-Rate Synchronous Dynamic Random Access Memory, better known as DDR SDRAM or DDR RAM for short, is a type of very fast computer memory. DDR RAM is based on the same architecture as SDRAM, but utilizes the clock signal differently to transfer twice the data in the same amount of time.
    DDR2 SDRAM uses 240 Pin Dimms.
    DDR2 SDRAM improves on DDR SDRAM by using differential signaling and lower voltages to support significant performance advantages over DDR SDRAM.
    If your question has to do with buying a video card that is going to use DDR2 ram, that would be a faster graphics card. You can also get video cards with DDR3 ram which again is even faster.
    Oddly enough in respect to system memory DDR2 is supposed to be faster than DDR yet the DDR memory cost more than the DDR2. Go figure.
    Click the link for video cards.
    Need help with anything, feel free & ask.
    Have a great weekend!
    Mar 21, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
    Gateway 5200XL PC Desktop Logo
    993 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
