Question about Brother MFC-845CW InkJet Printer
Why won't the new ink cartridge work?
I just purchased new ink cartridges from Target. I replaced the yellow and it still says no cartridge Cyan. What do I need to do. I mean, I just opened the plastic seal and took off the yellow plastic cap.
  • Anonymous Jan 23, 2009
    Same Problem Here with black tried everything i can think of tried 4 new cartriges still the same :-(
  • v2fst2kch Feb 25, 2009
    installed new blk cartridge and printer states bl is low.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
I have been given a canon pixma MP160 with no ink cartridges. what sort do I look for in the store.?
This printer uses 2 ink cartridges.
  • Ink Cartridge Configuration 1 black cartridge, 1 color cartridge (cyan, magenta, yellow)
You need to purchase the cartridges that suit this model printer.
If the printer does not print properly then the printhead may be faulty and needs to be replaced, BUT these are expensive. It may be better to put your money towards a new and better printer as a new printer is not much more expensive than the cost of a new printhead.
Jun 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
My G85 wont print yellow
This can happen for very old cartridges, even if they still have ink. The cartridges have a shelf life and can lose colors (usual yellow and cyan first) if stored for years.
If this is an original HP cartridge check the cartridge warranty date as shown here. If the cartridges are within their two year warranty call HP at 1-800-HPINVENt or contact your dealer for replacements. If the cartridges are beyond their warranty period then purchase a fresh cartridge.
When buying new cartridges look for the "install by" date on the package. I would look for a package with at least six months remaining before the "install by" date, which would have a year of remaining warranty.
When storing unused cartridges for an extended period keep them in a cool place and keep them upright as they would hang on a store display. This will provide maximum shelf life.
You can verify the issue is the cartridge by carefully blotting the printhead on a damp tissue. A good cartridge would have a stripe of Cyan, Magenta and Yellow, your cartridge will only show Cyan and Magenta.
I am sure that a fresh cartridge will solve your problem.
Regards,
Bob Headrick, MS MVP Printing/Imaging
May 09, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Error 1681 more than one Cyan cartridge installed
I have the same issue as well - I just open the printer, pop out the cyan cartridge, and reinsert it (the same one). This generally works - sometimes I need to do it once or twice. I figure I'll be patient and keep doing this until I a) finish the cyan ink cartridge, b) replace it out of annoyance, or c) through the printer out the window in total frustration.
Interesting to hear about "faulty" cartridges though - I shell out for the "authentic" Canon cartridges which you would think would be reliable - maybe I should switch to using the imitation ones if I'm going to have issues with them anyway...?
Feb 03, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Ink Cartridge Error PIXMA MP830.
pleaz clean the cartridge sensor and also align cartridges by program in your manual
Sep 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Brother MFC-845CW InkJet Printer Logo
119 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
