Question about Reddy HEATER RLP100 100,000-BTU PORTABLE PROPANE FORCED AIR HEATER
Reddy heater blows cold air
Reddy heater will only blow cold air. It will run continuously, but only cold.
  • Reddy Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
Rlp35 reddy heater runs few minutes flames out, fan continues to run?
clean the sensor so that the control can have confirmation of ignition
Nov 11, 2012 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
My ready heater 100,000 will run for app. 5hrs then flame out and blow smoke or unburned fuel the same several times pressure is right
If the heater continuously has a 5 hour run-time check to see if the fuel pickup tube goes to the bottom of the tank. If broken, cracked, or shortened the fuel will stop being picked up when air is sucked rather than fuel.
Feb 08, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
My 110,000 reddy heater flames up then after a minute or two just blows cold smoke???
Time for a Full tune-up, plug--fuel filter- 2-air filters -vanes in the pump.
Dec 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater 60000 btu kerosine heater
it either has too much fuel or not enough air. you will have to adjust both to figure out which is the culprit
Dec 12, 2009 | Reddy Heater 60,000 BTU Kerosene...
Fan runs backwards forces flame to blow back into heater instead
cracked heat exchanger not cheap replace unit ur motor just doesnt change rotation on its own
Jan 13, 2009 | Reddy Heater RLP100 Portable Forced Air...
REDDY HEATER R165AT
in order for the unit to fire up, the little air compressor on the rear of the fan needs to provide 3.6 lbs of air. if your nozzle is clogged it won't fire. for more troubleshooting tips try www dot desatech dot com. this is a site for reddy heat products and parts.
Dec 03, 2007 | Reddy R155D Utility Heater
Heating & Cooling Logo
738 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
