Question about Samsung ML-3561ND Laser Printer
ML 3561ND engine fuser. low heat error??????
Our new Samsung ML 3561ND Laser printer has been working fine until we attempted to change the toner, we put the new toner in and the on line / continue button came on in red?orange and the message 'engine fuser. low heat error' came up. I have tried turning it on and off and also unplugged it for half an hour left it and switched it back on...no change! help!
  • 2 more comments
  • roycie Apr 09, 2008
    Just change a toner cartridge and about a few hours after I received the Engine Fuser Low Heat Error.
    Whats the solution to that, the printer is fairly new.
    rsexcess@hotmail.com
  • Anonymous Apr 18, 2008
    Our new Samsung ML 2510 Laser printer has been working fine until we
    change! help!
  • Anonymous Apr 23, 2008
    LOW ENGINE FUSER, LOW HEAT ERROR
  • emey_111 Apr 12, 2009
    my Xerox printer suddenly started to show this message .."engine fuser..low heat error"
    tried to replace the toner ,checked for jam but nothing worked.:(
It's in the onboard computer system itself. This is a pre-set by the company that is designed to force you to service the unit, buy parts, etc., whether you need them or not. It is dirty pool I agree, but unless you know how to get into the machine's maintenance menu to re-set all those factory settings, you are pretty much screwed.
This is a nice printer, and what Samsung has done here is a travesty to our trash problem. It will turn out that it is much cheaper to just buy a new printer and toss the one you have, ergo, you are throwing away a perfectly good working printer all because the greedy foreign corporation knows "Stupid Americans" will buy more and more.
There is a way to get in, but it is VERY hard to do, but you are welcome to try:
You can enter the menu in this way:
Start up the machine with push in the buttons "online" and "cancel"
--You will see the message "Download mode press online key"
Press about 15 times the "menu" key
--You will see the message "Uncheck consumable mode"
Press about 15 times "menu" and 5 times "enter"
--You will see "Press access key"
Press a few enters
Press 3 times "cancel"
Go to the EDC mode
-- you will see "press access key"
Press "cancel"
Go to maintenance and initialize the parts you like to reset.
(sometimes you have to try a few times; don't wait to long between each of the steps)
Your printers are NOT broken. It is all in the design and how the likes of Samsung, Sanyo, Toshiba, etc., have figured out a way to screw Americans over, why, it's the favorite Euro/Asian pastime, see how many times you can get brainless Americans to buy your product over and over and over and over, on and on ad nauseum.
I wish you all much luck!
Now, here is what I did, and I do NOT recommend it:
I went to Comp USA and found the floor model. I wrote down the serial number off the back, went home and called Samsung with that serial number - and I was told "Your printer is still under warranty, we'll send someone to your home to repair or replace" How lovely of them. And replace it they did. Now, I haven't gotten the error message with this one, but if I do, I'll do the same thing again. Screw me once, shame on you, screw me twice . . . . .
Posted on Feb 27, 2010
  • 106 Answers
If you have annother tonner cartridge, (the old one will do)fix it and see if it works. If not there might be a component faillure related to the Fuser Unit. Also check for any Jam in the Pinions(Sometimes Samsung Laser Displays wrong MSG.)
Posted on May 06, 2007
Turn off printer and check temp of the fuser - if cool replace as is faulty.
Parts View PDF
http://www.mk-electronic.at/hersteller/PDFDokumente/Samsung/SW-Drucker/ML-3561ND_SEE.pdf
Posted on Apr 12, 2008
SOURCE:
Solutions for "engine fuser low
The "fuser" should heat-up to its operating temperature to "melt" the dry toner-ink onto the paper.
If it is not heating up, then each page you print and brush with your fingers will remove the toner.
So, replace the fuser, or get it professionally replaced.
May 15, 2011 | Samsung ML-3561N Laser Printer
Low Heat error...Cycle Power Samsung ML-2855ND printer
There is a problem with the fuser unit. This unit fuses the toner powder to the paper and if it is not hot enough the toner powder won't bond onto the paper.
Try removing the fuser unit, check the two fuser power spring contacts, and insert it back in the printer. If the error still occurs then you may need a new fuser unit.
You may need to get the printer checked out by a technician.
Mar 19, 2011 | Samsung CLP-600N Laser Printer
Samsung ML-1710p - when attempt to print, leds start slowly blinking simultaneously, "on line / error" - red, "toner save" - green
May be rejected this toner unite or paper could not feed properly.Service thoroughly your printer and Fuser unite.
Nov 27, 2009 | Samsung ML 1710 Laser Printer
The ML2851DN cycles on but then has a red light that stays on.
The red light stays on until paper is loaded, and also if there's a problem with the fuser not heating, or toner is empty.
Oct 09, 2009 | Samsung ML-2851ND Laser Printer
You need to replace the fuser in the printer, the part number is JC96-03406A You can do a google search for the best price.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Samsung ML-3561N Laser Printer
Replace the fuser, it's not reaching operating temperature within a set time (normally a thermister or the lamp is shot)
May 21, 2008 | Samsung ML-3561ND Laser Printer
Fuser Door/s
Your Samsung ML-3561ND looks to be an HP Laserjet 4000-series printer. Same engine, different electronic. The fuser is in the rear of the machine, and may be relating to the drop-down rear panel where you clear paper jams. Open it and give it a good push closed and the printer should cycle and come ready. Let me know what happens!
May 07, 2007 | Samsung ML-3561ND Laser Printer
Basically the error message is telling you the printer cannot keep the fuser temperature at the proper temperature (too low). It could be a lot of things but typically it is due to a fuser assembly gone bad.
Feb 20, 2007 | Samsung ML-2551N Laser Printer
Samsung ML-3561ND Laser Printer Logo
2,661 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
