Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
IF error ignition fault lockout
Hi I have a hayward h400 and have no used the heater for about 4 or 5 months. I guess it would have been a good idea to turn on for a little bit once a month. Now when I turn it on i hear air coming out but do not hear the ignition go on. It tries several times then gives me an error of IF ignition Fault lockout. Is there anything I could do to fix?
thanks
Ben
You are absolutely right. This is the third season for my pool and last year I had the same problem on my H400 heater; an IF (ignition Failure) code. The spider webs on mine were up in the brass orifices, not just on the tip. I pulled each of them out (7/16" wrench); if I had had a pipe cleaner I might have been able to clean them without taking them out. If you use a pipe cleaner, I recommend running it 1.25" to 1.5" up into the brass fitting to get all the webs cleaned out.
The heater ignited the first try after the cleaning and is working normally. Thanks for the input from ifixpools.
Posted on Feb 09, 2009
  • 22 Answers
If it has not fired in some time, the odds are high that a small spider web is blocking the burner orifices. These are the brass fittings exposed at the front of the burner tray. It does not take much to block gas flow. Each burner should have a pipe cleaner run into the orifice. A small zip ties will also work. You're looking for a small web on the end of the cleaner.
The problem lies in the blockage. The ignitor and flame sensor sit at two different burners. Blockage of a burner at those locations will not ignite or will not sense flame to allow the heater to stay on.
Restart after cleaning and see what happens. Otherwise, you may have a bad ignitior.
Posted on Jan 01, 2009
Had a power outage yesterday now heater won't ignite. No error codes.
bo = 'Bypassed Operation'
heater is now controlled via your automation system.
Create a heat call, turn solar off if active.
Heaters should be set to auto on.
Mar 07, 2015 | Hayward Pool Products Hayward Universal...
How to replace the Thermostat in Hayward pool heater
go to pool store and spend the money on
Alladin or Magic Lube. It is a bit expensive and a good sized tube but its designed for your pool system. use it on all your gaskets and threads. DO NOT USE PETROLEUM BASED (vaseline)
Jun 07, 2014 | Hayward H-series Electronic Gas Pool...
Error code
make sure water filter is CLEAN ! this will throw a code
Jun 22, 2013 | Hayward H-series Electronic Gas Pool...
Hayward H-Series Not heating water
if all burners are working correctly then put a bypass on heater plumbing open it half way to slow down water flow that will give you a higher heat rise
May 05, 2013 | Hayward H-series Electronic Gas Pool...
IF error code when trying to start
Error IF is ignition failure.
Last page shows troubleshoot walk through ranging from low gas pressure to bad gas control valve to failed wiring etc
http://waterheatertimer.org/pdf/Hayward-error-codes.pdf
Oct 28, 2012 | Hayward H-series Electronic Gas Pool...
The CE code is showing on screen
Communication error
If communication between the ignition board and the display board is not established
within 3 s of power-up an error will be displayed. After communication is
established, if it is lost for 30 s, the error will be displayed. The error code will
be cleared upon a valid data exchange between boards.
May 18, 2012 | Hayward H-series Electronic Gas Pool...
I can not turn off ob on the screen of my Hayward pool heater
I looked up the owners manual for the Hayward H400 heater and it did not list the "ob" indication. For this reason I would call the and they likely can help you out.
Please let me know how this turns out. Thank you.
Aug 30, 2011 | Hayward H-series Electronic Gas Pool...
I have a hayward 400idl heater that is stuck in stand by mode. any ideas?
Hi
If you have a auto control system like a Aqualink,Aqualogic Put the controller in service than select heat. Check and make sure the service light is not on also. What happens when you press the mode button. If nothing and the button membrain looks good. open the front panel there is a ribbon cable that goes to the display and plugs into a control board in the back. Unplug the cable and plug it back in "Be Careful The Pins bend very easyly. Try the mode button again. Is there any error codes on the display?
Jan 07, 2011 | Hayward H-series Electronic Gas Pool...
Hi I have an H400 hayward. when heater is activated, it stays on for 5 seconds then shuts down eventually reading ignition failure code or IF on screen. the ignitor is new, the heat sensor is new, the gas...
When you say it stays on, Does the main burner actually light? If the burner never lights, then I'd look closely at the igniter, as it also acts as the flame sensor. Possibly you have a good enough ground to get a spark, but not good enough to sense the flame. If the main flame is starting, look and see if it is blowing off of the igniter. If this is the case, perhaps it isn't in the correct position, or there are still a few dirty passageways in the main burner. You can download a manual for your heater here: http://www.haywardnet.com/products/Manuals/pdfs/Manual285.pdf
Aug 10, 2010 | Hayward H400 High Wind Stack
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
1,559 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
