Worked ok for about an hour then just stopped and will now not switch back on, replaced fuse just to check if it had blown and for about 2 sceonds it started then went off again.
SOURCE: karcher washer went dead
Dear jimbocom,
The problem is that the spill valve got stuck. When the machine is working and the gun is closed, a valve( spill valve) moves with the accumilated pressure and switches the machine off. So what happened is that when the spill valve did its job, it found no water...and remained stuck. This leaving the machine in an off position. Service and lubrication to the spill valve must be done or completely replacing with a new spill valve. In my opinion you have no serious damage, but this job must be carried out by an expirienced technician.
Regards,
MG.
SOURCE: Karcher B402 pressure washer Motor runs as soon
bob I had this happen to my Karcher, the pressure seals have blown. $Au200 for service and replacement from karcher dealer. tyhey would not sell the parts for a DFY
Its possible that the on/off switch is defective. It happened to mine. It made the click sounds like it was switching but it really wasn't. The part number is 90010480. You can get one here: http://www.pressureparts.com/catalogsear...
It is possible that the on/off switch is defective. Mine was even though is seemed to click on and off. Internally it was bad. The switch can be bought here: http://www.pressureparts.com/catalogsear...
