Problem with Panasonic CQ-DVR909U Car DVD Player
DP Video car system to play video
6 Solutions
I bought a DP Video car stereo with a 6" monitor from Frys as close out special. I have installed the unit to my car successfully. The stereo does what it is supposed to do but when I insert a DVD to play a movie, the sound is there but the screen shows "Warning - DO Not watch movie while driving". I was trying to find out how to show the movie but the unit does not come with a manual.
There are no internet sites also for the unit. HELP
  • avatar
    infantemarin same problem here guys....for most part the solution is just grounding that brake wire....or putting a hot wire with a switch....is the only answers I've read online...good luck with DP VIDEO from FRYS ur right comes with no installion instructions....
    Mar 09, 2009
  • avatar
    deseat28 I have the same issue with the dp video model: dbd803bl
    Jan 08, 2009
Guest
8,029 people viewed this problem
  • 16 people found this problem to be helpful.
  • 0 people are following this problem. Be the first!
More Insights on Fixboard
6 Solutions
  • khaye1
  • 2 solutions
  • Jan 12, 2009
This solution has been voted best by the Fixya Commnunity
Look at the install diagram(wiring codes) that came with the unit. if it has a wire that's designated for the parking brake (allowing you to only watch dvds while brake is engage) take that wire and instead of hooking it up to the parking brake, ground it or put an in-line switch between wire and ground so you can turn that function on and off. warning!!! watching while driving is illegal in most states
You need to get a video cable and hook up the ground on the back of the radio
Hook up the brake wire(pink wire) to the ground(black wire) also when installing to your wiring harness. Picture now shows.
There is a wire that has to be connected to the handbrake wire(gound).
the wire normaly is green
Simple as that.
Ric
The screen was working finebut all of a sothern it went out. the touch screen doesn't work
You can download the manual from:
ww.dpaudiovideo.com
it should have the wiring diagram in there and tell you if the signal wire needs to be hot or grounded
Add your solution
Full Name
Top Panasonic Car Video Players Experts
Trent Macleod
  • Solutions: 17
  • Level: 1
  • Achievements: 1
kenw392
  • Solutions: 2185
  • Level: 3
  • Achievements: 2
EMMANUEL DIAZ
  • Solutions: 111
  • Level: 2
  • Achievements: 1
Expert Badge
Are you a Panasonic Car Video Player Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More CQ-DVR909U Car DVD Player Related Problems
Unsolved Problems:
See all Panasonic CQ-DVR909U Car DVD Player Problems
Loading... Loading...
