Frigidaire FEF336BC Electric Kitchen Range Logo
Posted on Oct 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No clock display
Display for clock is not displaying cannot use timer everything else is good so far
  • Official Brand Answer 4,342 Answers
  • Posted on Oct 12, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467805
Points
5907
Hello - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately two minutes and turn on the range. Attempt setting the clock, if it is ineffective then I would suggest contacting a professional to move forward accurately. The range may possibly have a faulty wiring or a communication issue with the EOC.
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Oven , light and fan not working new element fitted 2months
Sometimes the timer display fades but still working in background, if all dead now then probably means you need new timer as ovens shouldn't work if clocks not set to manual mode.
Try turning oven on then messing with buttons, usually the 2 left buttons and one far right should do trick.. push 2 left first, keeping them pressed push far right!
warmest regards
Richard The Repairman
I am trying to st the timer to turn on at 5PM and turn off at 11PM.
You posted under Intermatic HB88RC timer
If you have different timer, add a comment
HB88RC timer manual:
http://waterheatertimer.org/pdf/hb88rc.pdf
HB88RC programming Instructions:
Install AA battery in timer so display will show, and you can program
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
If you want all week long, then press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 5pm shows >> this is event1 ON
Press Min button until :00 displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Match days with ON time: so press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 7pm displays >> this is event1 OFF
Press Min button until :00 displays for event1 OFF
When programming is finished, press clock button to display current time
When programming is finished, press MODE button to select MODE > you want AUTO for timer programs to operate
Press MODE button once and this is manual override, and lights come on.
Press MODE button again and RDM displays, this is for random timer operation
Press MODE button 3rd time, and timer is set to AUTO
After setting MODE to auto, press clock button to display current time.
Plug timer into receptacle.
Plug lights into timer.
I DON'T KNOW HOW TO PROGRAM THE TIMER I'VE LOST THE MANUAL. I NEED TO SET IT MON- SUN FROM 7PM TO 12PM IT SHOWS: 1 ON THIS IS WHERE I HIT HOUR & PUT 7:00PM THEN I HIT PROGRAM IT SAYS 1 OFF I HIT...
Here's HB88RC programming from the top:
Remove batrery from back of timer to reset timer and clear everything.
Re-install AA battery in timer so display will show, and you can program
Set clock:
Program timer:
This is Event1 ON
Press Hour button until 7pm shows >> this is event1 ON
This is Event1 ON
Press Hour button until 12pm displays >> this is event1 OFF
Add a comment any time.
A lot of folks have written in about this timer going bad and they have been unable to program the timer. Of course most timers work perfectly fine.
5helpful
I need instruction for the timer
You posted under Woods 59403 timer
If this is not your timer, add a comment.
59403 timer manual:
http://waterheatertimer.org/pdf/Woods-59403.pdf
If you have different Woods timer, look at images at link below to identify timer.
Add a comment if you need help.
http://waterheatertimer.org/Woods-timers-and-manuals.html
59403 programming Instructions:
Plug timer into indoor or outdoor wall outlet.
Set clock:
Program timer:
This is Event1 ON
Press Hour button until selected hour displays for event1 ON
Press Min button until selected minute displays for event1 ON
This is Event1 ON
Press Hour button until selected hour displays for event1 OFF
Press Min button until selected minute displays for event1 OFF
Press PROG button until 2 ON displays
This is Event2 ON
Repeat steps above to set up to seven events.
Recommended you make chart of your on-off times before starting to avoid conflicts in programming.
When programming is finished, press MODE button until automatic displays.
To override programming, press MODE button until lights come on.
For random operation, press MODE button until RDM displays
I would like to have the instructions for operation of the Timer.
Add a comment at any time
59403 timer manual:
Set clock:
Program timer:
This is Event1 ON
This is Event1 ON
This is Event2 ON
On my intermatic HB88RC,I replaced the battery because it was dead and now it shows 44:44 on the display can this be reset?
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC is 7-day plug-in digital outdoor timer that uses AA battery installed on back of timer to power the display.
People write to fixya frequently report Intermatic timer stops working after replacing battery.
To check if your timer is still functional:
Press and hold clock button.
Press Day button until current day shows in display.
Press Hour until current hour shows in display
Press MIN until current minute show in display
Release clock button.
If current time shows in display, then timer is probably still good.
To set programs:
step 1) Press PROG button until 1 and ON show on display.
This is program1 ON.
Press day button until choice of days shows for program1 ON
Press hour until hour for program1 ON shows
Press MIN until minute for program1 ON shows.
step 2) Press PROG button until 1 and OFF show on display
This is program1 OFF.
Press day button until choice of days shows for program1 OFF
Press hour until hour for program1 OFF shows
Press MIN until minute for program1 OFF shows.
step 3) Press PROG button until 2 and ON show on display
Repeat steps above to set program2 thru program7
step 4) When programs are set, press CLOCK button to return to current time
step 5) add a comment for more help
How do I set the current time on the Woods Digital Timer Model#59203?
78a8604.jpgWoods 59301
Manual for 59301
http://waterheatertimer.org/pdf/Woods-59203.pdf
Plug timer in wall for 1-2 hours so rechargeable battery charges
If display does not show after 1-2 hours, the battery is dead and timer is no good
After 1-2 hours, you can remove timer from wall to program
Press reset (R) with paper clip to clear memory
Select format: Press and hold Clock button until 12 hour or 24 hour shows on display, then release
Press hour button to change display to 12H
press Clock button and display returns to normal
AM shows in upper left corner
Set current time:
Press and HOLD clock button
While holding clock button, press hour button and minute button until display shows current time
Press and HOLD days button until current day shows in display
Release days button
Further instructions to set ON-OFF times are in manual (click link shown above for manual)
If you have problems, re-post additional question.
3helpful
3answers
Clock problem
had same problem but didn't fix it because i don't use the clock. after a few months it got worse, can't set the time (clock always flashing) so the oven doesn't work.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
