Hotpoint aqualtis aqxxd169 washing machine will not drain or spin
  • Washing Mach... Master
  • 3,463 Answers
The m/c will not normally spin if there is a lot of water in it.
You need to check the pump to see if it is working o/k, and check the filter also.
The filter is located behind the bottom kick strip at the front.
Undo screws ,remove strip and unscrew the pump cover anti- clockwiwse to remove, be care ful as there will be some water run out.Clean filter and try again.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
2 Suggested Answers
  • 460 Answers
SOURCE: My Hotpoint Aqualtis washing machine leaves
the drain **** in the machine is partially clogged. my best guess is at the water pump. your washer needs to be serviced. call a serviceman..
Posted on Nov 15, 2009
I have a Hotpoint Aqualtis wash/dryer which stopped working with a 'F12' fault. Now when I turn the socket on I get an immediate really loud whir/buzz.
possibly the main drive belt has either snapped or jumped off the pulley and this allows you to turn easily by hand the whir/buzz sounds like system in coming into play but with no belt to drive nothing more happens, the front lower portion of the machine could be the water pump working overtime unable to drain ???
May 09, 2016 | Hotpoint Washing Machines
Hotpoint aqualtis AQXXL 129PI
could be a bad timer? sticking at the wash cycle. it does agitate right? other wise bad water pressure switch
Aug 07, 2014 | Hotpoint Washing Machines
Hotpoint aqualtis not draining
Hi.
Check the drain hose at the back and access the drain filter located at the bottom side of the appliance.
Please click here to read an article showing how to fix common drain problems.
Regards.
Ginko
Apr 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Nov 15, 2009 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
A hotpoint aqualtis aqxx149pm spinning loudly
Hi, This is a common problem with the hotpoint range. It will be the main wash bearings that have failed and need replacing. This is a very easy process but is quite time consuming. Remember tho change everything that is; Bearings, and bearing spider and front tub seal as you dont want to have to do it again in a short time or have leaks coming from the front.
Good luck and get back to me if you need any further help....................
Jan 02, 2009 | Washing Machines
Hotpoint Aqualtis Error code F11
please could someone help as i have the exact same problem with my aqualtis zqxgf149,exactly as above,fitted new pump myself and its now emptying the water but wont spin and in wash cycle f11 comes back up
Jun 27, 2008 | Washing Machines
Washing Machines Logo
401 people viewed this question
Top Washing Machines Experts
