Question about Canon PowerShot A520 Digital Camera
Black screen My camera turns on but when I am in the "auto" mode, the screen is black. The camera takes pictures though. I have changed the batteries several times - that has not had an effect. At times the red battery light flashes although the batteries are fine.
You probably just pressed the DISP button on accident (its on the lower right hand corner of the screen) to turn the screen back on, push the DISP button. if that doesnt work, i would get it looked at by people at Canon.
Posted on May 03, 2007
My Nikon D70 camera takes pictures that come out completely black
Check the MODE. With ANY camera with manual mode you can take black (underexposed) photos all day. If photos are black try and use an AUTO mode. Typical it has a GREEN Camera symbol. So many things can be set wrong on the camera and they are beyond this answer.
Feb 12, 2018 | Nikon D70s Digital Camera
Screen went black
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Feb 27, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
While taking a photo snap, don't see the picture on the screen. Screen is black. Can see the old picture on preview mode without any problem
Sounds like you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on and off to save batterie (you would then use the optical viewfinder in its place). Press this button once to see if it corrects the problem.
If the above didn't help, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 07, 2009 | Canon PowerShot SD1000 Digital Camera
Black screen
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Oct 06, 2009 | Canon PowerShot A510 Digital Camera
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
Black screen, black pictures
Set to auto shooting mode, take pictures, if still get black pictures, you need to repalce the lens unit. CCD or shutter defected.
Jul 08, 2009 | Olympus Stylus 720 SW Digital Camera
Canon Powershot A510 black screen when taking photos
Jun 20, 2009 | Canon PowerShot A510 Digital Camera
Camera screen remains black when I turn on shooting mode
Turn the camera on. With the screen showing, press the DISP button and this will give you a selection of different screen views i.e. squares for aligning shot squarely; black - thru viewfinder only; etc. Different modes will give you different screen displays i.e. P setting screens are different to when you have the camera set on AUTO.
Hope this helps.
Jan 11, 2009 | Canon PowerShot S51S Digital Camera
Canon PowerShot A520 Digital Camera Logo
121 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
