Question about Whirlpool Duet GHW9150P Front Load Washer
An open coat hanger went through a hole in the drum
We have a frontloading Whirlpool Duet Washing Machine. We washed a "cathouse" that my daughter made and didn't realize there was coat hanger wire that helped to support the roof. After washing, we found one piece of coat hanger halfway lodged through a hole in the drum. After further investigation, we found another whole piece of coathanger wire that is laying under the drum. We have attempted to get it back through a hole without much success. Any suggestions?
  • kathryncj5 Jan 05, 2009
    Thanks. Unplug the unit was a great thought that we didn't do. We ended up drilling one of the holes in the basket a tiny bit bigger and managed to pull up the hanger through that hole. Thanks for your ideas.
  • 640 Answers
Aways unplug unit first...get another coat hanger,,and tape amagnet to it,,if magnet to big smash it,,pretty quick,,if that dont work ,,reply back and i will talk you through taking the tub to pump hose off.and pushing it out,,but do not flush water through,,because if it gets in pump impeller,,we are going to have a new years mess,,,happy new year
Posted on Dec 31, 2008
My whirlpool duet sport frontloader wont drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 04, 2010 | Washing Machines
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Frontload Duet. The tub will not spin, the belt
I am not an expert but I would suspect a failing bearing has seized up. Mine would spin one direction, but not the other. I worked it and got it to go both ways, but with a snapping sound. This is checked by spinning the pulley with the back panel off (machine unplugged of course).
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do we fix the washing machine when it says, system locked
unplug for a minute then plug in or turn circuit off for a minute and back on. It worked for me.
Jun 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
SUD F35
run a wire and, patch through your tub pressure switch hose (like a guncleaning rod) a coat hanger annd, papertowel works well it should be clear all the way from the tub to the water level switch
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frontloader washer
make sure your drain hose is above the tub in the washing machine
Feb 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I need a parts diagram for the whirlpool duet hp frontloading wash machine
go onto sears.com..find parts online order.click onto and enter model number..should bring up pictures of parts breakdown
Sep 28, 2008 | Whirlpool Washing Machines
Whirlpool doet washing machine
the door on any frontload whirlpool washer cannot be changed from side to side.only the dryer
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
76 people viewed this question
Dan Webster
Dan Webster
Sal De
