Question about Sony KP-65XBR10W 65" Rear Projection Television
Sony KP-65XBR10W Projection TV has no picture or sound
We have a Sony KP-65XBR10W Projection TV and the other day we turned it on and heard a pop and now we have no picture or sound the only thing the TV does is the stand by light on the front blinks non stop.
Please Help tomorrow is new years eve and we will have a house full and no TV!
  • jennielagrac Dec 31, 2008
    we found a buned out fuse 6.3 amp could this be the problem?
    Any Idea where to get fuses from?
  • 495 Answers
The steady blinking light means there is no specific code. Sony authorized repair said the double-side board (the one lying flat/horizontal just to the right of the vertical power supply board which has the fuses) has a burnt transistor (the one with the sizable heat sink on it, at the back left corner when looking at the board from the rear of the TV). It is blowing the (non-power supply) fuse.
Posted on Dec 31, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, to address your concern and your query:
  • visually inspect the defective fuse;
  • if the burned out fuse is clear with just the fine wire inside cut, then it would be safe to replace the fuse;
  • if there are burnt marks, black particles inside coating the glass tube, then that is indicative that there is a hardware fault that caused the fuse to blow. In this case, it would not be safe to simply replace the fuse;
  • if the fuse is relatively near the AC?power cord, then probable fault would be in the power supply section;
  • if the fuse is after the power supply, then it would be any of the other circuitry that is at fault. primary suspects would be the big loads like the HOT (horizontal output transistor).
  • fuses are readily available from most electronic stores, hobby shops, audio/video stores and even in some computer stores. Even your local hardware store could have some in stock.
Good luck and Thank you for using FixYa. Happy New Year.
    President:
  • 2,110 Answers
Hi just to let you know its an indication to your bulb
has gone faulty
its a expensive repair around £300 pounds plus fitting
    Novelist:
  • 163 Answers
Yes..
try a new fuse and see the result.
  • ronny2051 Dec 31, 2008
    k..
    purchase it from the blow link
    http://www.google.com/products?client=op...
    Sergeant:
    Champion:
  • 304 Answers
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Posted on Dec 30, 2008
  • 10,594 Answers
Most probably horizontal deflection section got some hardware problem and requires few parts replacement.
Let me know do you have Tv repair experience and knowledge of electronics to guide you more to fix it by yourself?
  • Shahid Electronics
    Shahid Electronics Dec 31, 2008
    blown fuse shows that few parts in power supply or horizontal deflection section are cooked.
    You can get required Fuse from HERE
Sony KP-65XBR
This is the sony support page. Try this out. Click here
Jan 12, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Sony KP-65XBR10W had blinking light
In your google toolbar type in Understanding Sony Blinking codes it will then take you to website that tells you what the blinks mean .
Sep 24, 2009 | Sony KP-65XBR10W 65" Rear Projection...
"pop sound", picture out, burning smell...?
Usually, yes. A bulb that has audibly 'popped' will be apparently bad if you pull it out of the TV (shattered). Other times this is a lamp ballast board.
May 18, 2009 | Sony KP-53XBR45 53" Rear Projection...
Major problem with sony kp-57ws500
BTW if you appreciate the help I have given you, please rate me! Thanks!
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
No sound Sony KP-57WS510
Brain Freeze ! Sometimes the microprocessor locks up...
you may need reset = unplug ac cord, wait, then try again..
..........T.
Jul 01, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp-65xbr10w led light blinks 5 times
i have a sony tv model kv36fs17. led flashes 5 times. tv works but no red color. would could be the problem? thanks
Jan 23, 2008 | Sony KP-65XBR10W 65" Rear Projection...
TV goes out
pyrosp4,
it maybe you blue crt (picture tube). mine turn blue and then shuts off. i got it repaired for 460. 300 for the part 160 to install. you can try to adjust the voltage settings behind the speaker screen and see if that clears the problem. if not its you blue crt.
pridah
Dec 18, 2007 | Sony KP-65XBR10W 65" Rear Projection...
Sony KP-53N74 Rear Projection TV won't power up
how was the picture before ? nice and bright if was ok it may worth fixing probable just power board get the hit ..
May 16, 2007 | Sony KP-53S35 53" Rear Projection...
Sony KP-65XBR10W 65" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
