Question about Hitachi 53UDX10B 53" Rear Projection Television
53 Hitachi Ultravison TV : Getting Horizontal lines rolling up
Horizontal lines appearing, rolling up as you watch a program; happening regradless of what channel your viewing. Please what do I have to do to get this corrected. TV is more than 10 years old.
  • ittybittykia Jan 18, 2009
    screen jumps as you are watching tv...similar to horizontal lines
    Hitachi model V2T2012889 - 60FX20B - October 2002
    Champion:
  • 240 Answers
Ok
this is called viedo noise
you will need to replace capisitor Cc10 its Value is 1000uf @ 16v the cap is a filter On Sw +9v Line , on pin 20 of Ic01, ( or corma Jungle IC)
Posted on Jan 12, 2009
Why do I have rolling horizontal lines on my hitachi big screen t.v.?
Need the model number of the Hitachi which should be listed n the rear cover. I should be able to assist but will need the Model Number to determine which chassis design you have.
Apr 02, 2013 | Hitachi Televison & Video
Hitachi 53SWX01W Distorted red lines and shadowing.
that is from a bad video board..try turning it off to reset the values, but I'm not confident it's recoverable without some serious technical help
Apr 27, 2008 | Hitachi 53UDX10B 53" Rear Projection...
How to set color, verticl and horizontal lines
Not all universal remote control's operate MENU button on TV!!!
If you have >>COLOR separation ( red blue green) and CAN NOT adjust via MENU button then you must replace conversion IC's>>
part number: STK 392-xxx.....easy repair!!
May 19, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Aug 30, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Rolling white lines
sometimes this can be caused by two connected devices being on the same av channel,try connecting one at a time,also check your tv is set for your region etc,pal or ntsc.and you could look in your tv settings menu and check your output ie rgb scart,forgot the other options,,hope this helps
May 25, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Anyone know
Usually this occurs when the Convergence ICs go bad along with some chemical fuses mounted on the deflection board. E994 usually blows along with the Horizontal out transistor going bad. This transistor, I believe is Q777 that usually goes bad. The fuses are either tiny little yellow fuse with a red band or green with a yellow band depending on your model number
Jul 08, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Scrolling lines in the picture
The capacitors in the sweep supply and maybe in the main power supply are starting to dry up. Your going to need to get a tech to go over the boards and search out the dryed capacitors. It will take some time and maybe a bit costly. May want to think maybe about a new set? Good Luck
Aug 14, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
380 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
