Question about Polaroid i1035 Digital Camera
Batteries For every 5- 10 pictures I take the batteries are dead?
  • 2 more comments
  • dogugotw Jan 04, 2009
    The camera seems to eat batteries (non-rechargables). It's worse if the flash is on, but even off, it seems to have a very high battery use rate.
  • Anonymous Jan 06, 2009
    I also received this camera as a christmas present. I used my rechargables from my 3.1mega pixel older polaroid and increased the amount of pics I can take.
  • marilyn_wms Apr 22, 2009
    I have tried all types of batteries to no avail. Good alkaline permit about
    10 pictures and silver oxide allow for about 12-15 pictures. I have even
    tried turning off all additional functions of the camera.
    The 1035 model is of poor quality and function. Blurry pictures and
    random shut-off.
    MW Gillespie, Il
  • John Norton
    John Norton May 11, 2010
    are you using rechargable batteries?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 11 Answers
Use the Energizer Lithium batteries. Should get close to 100 pics.
Posted on Feb 05, 2009
2yrs old. Went thru 3 sets of batteries to get 20 pictures. Dead again. What`s the story?
Sounds like you have a short in the wiring. This is repair shop stuff, or buy a new camera time. Usually, if it is a point and shoot , it is not worth sending for repair as you'll playas much as a new camera is worth. I would look for a new camera, personally. Good luck.
Oct 20, 2014 | Cameras
I got the kodak easy share 143 model camera coming brand new off of ebay yesterday,,,but it keeps saying my batteries are half drained, then dead after a couple of photos. Then if they're dead it...
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 26, 2011 | Kodak Cameras
Batteries go dead when trying to download pictures to my computer
Transferring pictures takes a huge chunk of electricity out of the batteries. The solution to this, is to use a memory card reader to download the pics. That way, you don't have to use the camera's batteries up downloading.
Jul 06, 2010 | Kodak EasyShare One Digital Camera
Draining rechargable batteries;
Carry spare alkaline batteries - just in case...
Does the same symptom happen with alkaline batteries?
Lithium Ion batteries are 1.2volts
Alkaline are are 1.5volts
Rechargeable Alkaline batteries are 1.5volts
Perhaps you should switch to Rechargeable Alkaline batteries if the symptom goes away when you use alkaline batts...
Sep 17, 2009 | Samsung Digimax D53 Digital Camera
Brand new batteries, take a few pictures, then batteries die
It may be something more serious, or your new batteries may be defective, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the startup problems. I hope it works for you.
Sep 07, 2009 | Cameras
Even with new batteries and they go dead before I take 3 pictures
Yes, there is definitely a fault with your camera.  You should be able to return it for a replacement.  I wouldn't experiment too much with batteries in this camera. batteries discharging this quickly are likely to overheat, causing unmentionable catastrophe.
Dec 11, 2008 | HP Photosmart M547 Digital Camera
Pictures
Yes, per the manual, if the batteries are removed for more than 60 secs or go dead and aren't changed the pictures will be deleted.
Dec 25, 2007 | Simmons Outdoor CaptureView VGA Binocular
Camera batteries drain quickly
Open the battery door and check the contact between the camera and the batteries. Most often then not there is just a bad contact and it's ruinning your baterry life.
Make sure that the contact are well placed and that there is no rust or dirt build up around there.
Sep 23, 2007 | Olympus FE-210 Digital Camera
Battery?
i just got mine today, and the batteries were dead withtin a couple of hours, so yes. mines has decided to go black, it was fun while it lasted,, theres £90 ill never see again
Aug 24, 2006 | Samsung Digimax S500 Digital Camera
Polaroid i1035 Digital Camera Logo
379 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
