Question about Toshiba 65H82 65" Rear Projection Television
Toshiba 65H82 problems with screen when using dvd or vcr
Hello Josh, I have a neighbor that has a Toshiba 65H82 TV and he indicated that when using his DVD or VCR his screen goes crazy. Does not get a clear picture, moves from right to left but not at the same time. He even bought a new home theater system and used the front plugs for the video and still received the same un-focused screen. So it does not seem to matter what input plugs he uses, rear or front as they both have the same problem. I took the back of his TV apart, made sure his connections, boards and plugs were clean from dust, as much as possible but it only seem to make the screen worse. So, that being said, I still think it may have to something to do with dust on the boards and maybe caused something to go out, I don't know. We even took the PD0075C circut board out which is where the rear connections are and made sure the contacts were all clean. Any recommendations or suggestions would be greatly appreciated. Thank you, David Jennings set is about 4 years old.
  • 1 more comment
  • wonderworm Nov 18, 2007
    Evidently this is an extremely common problem in the Toshiba 65h82, 57h82, 50h82, and 47h82 rear projection CRT sets. We should probably get a class action lawsuit going on or group together and send our complaints directly to Toshiba management.
    But this is a latent defect in these Toshiba HDTV's and we all basically got screwed. For mine the only input left that I can even recognize a picture is the Colorstream HD input and even that one is about to go out. If I try to rent a DVD and play it...horribly wavy and massively distorted screen. Same for my XBOX 360 on the front inputs which I now have to play on a 22'' screen because this POS 65'' Toshiba is defective.
    I have read that you have to basically replace a bunch of fried capacitors on one of the boards and you may be able to get it working again.
    I'm sure many would appreciate a detailed guide with pictures on exactly what needs to be done if there is anyone out there who has solved this problem with these rip-off TV's from Toshiba.
    Definitely my last Toshiba product unless they make good on a remedy for everyone who they screwed over by selling a TV that breaks at 13months.
  • Anonymous Dec 02, 2007
    Seems as the i'm not the only one with this problem 65H82 w/messed up screen
  • Zikes Jan 04, 2008
    same here the only thing that comes in good is the Colorstream HD when I have my HD Dishnetwork reciever pluged into it. if I plug my dvd play, xbox360 or PS3 into that same connection the screen goes crazy I guess the dish network reciever has a stronger output signal. I am going to take the back panel off this weekend and see what I can do..
4 Suggested Answers
SOURCE:
techman
  • 3130 Answers
SOURCE: video input problems
If its a brand new set and never worked from the get go I bet ya 10 to 1 that theres a plug or clip lose in the set someware. Hope ya got a warrantee as you should have unless you bought if off A corner someware. Call the repair service # thats in the owners manual to get it fixed asap. Good Luck
Posted on May 28, 2006
JULIANFIX
  • 975 Answers
SOURCE: Toshiba Theater View 65" Projection TV Blinking Power Indicator LED>
if your handy , I suggest to check for any DRY SOLDER in the PC BOARD around the power supply ,or check the Convergence area for some IC , its start with STK___ and numbers. hope it helps
Posted on Apr 26, 2008
SOURCE: Toshiba 46HM95-Picture Blinking Green
Late info but that is a color wheel for people having that problem, it either flew out a part or the motor is failing and can't keep the phase correct. what is sad is this would be a 100 buck part for other brands of DLP TV but Toshiba is modular and the color wheel is in the light engine module and that ups the price to 500+. If you are inventive and careful you can take the color wheel from it's motor and relube the bearing, I have had luck with high temp lithium grease. And there was a class action lawsuit about bulbs failing too soon. The UHP bulbs do some times fail early but Toshiba is known for it
Posted on Jul 08, 2010
How do you use the VHS function on the Toshiba DVR670 player?
Because this product is a combination of a VCR and a DVD recorder, you must select first which component you wish to operate with VCR/DVD DVD mode Press DVD on the remote control. Verify that the DVD indicator is lit VCR mode Press VCR on the remote control.(Verify that the VCR indicator is lit OR I set up this pdf link...click on it and it will show you all necessary steps http://www.helpowl.com/manuals/toshiba-dvr670-owners-manual-english-70453af.pdf
Oct 20, 2011 | Toshiba DVR670 Player
Tip
Dish Network Combo TV/DVD Remote Codes
CODE Broksonic TV/VCR 748 Goldstar TV/VCR 747 Panasonic TV/VCR 747 Quasar TV/VCR 747 Samsung TV/VCR 738, 755 Sylvania TV/VCR 756 Zenith TV/VCR 747 Aiwa TV/DVD 751 Apex TV/DVD 757 Broksonic TV/DVD 752 Konka TV/DVD 753 Panasonic TV/DVD 734, 765 RCA TV/DVD 749 Sansui TV/DVD 754 Sylvania TV/DVD 764 Toshiba TV/DVD 750 Go Video DVD/VCR 692, 693 JVC DVD/VCR 689 RCA DVD/VCR 690 Samsung DVD/VCR 738, 667, 691 Sony DVD/VCR 768
on Jun 06, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Hello i have a toshiba md9dm1 tv/dvd combo and i lost my remote I have a universal ge remote none of the codes work Do you know the code for my tv/dvd combo?
hi,
If you remote is a 4 digit one then the codes are
0394, 0924
If the remote is a 3 didgit one then the codes are
394, 902
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the
INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR,
DVD, etc.). For AUX, press AUX then the device button you are assigning to
AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the
GE Universal Remote. After your code is entered the INDICATOR LIGHT will
turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER
button. Your device should turn off
OK
Aug 03, 2011 | Toshiba MD9DM1 9 in. TV/DVD Combo
New DVR67)KU toshiba DVD video recorder/VCr recorder Problem: Cannot get on-screen display to set up new DVD machine. Both DVD and TV are Toshiba
unplug everything lets start over.....the TV is set on Ch 3..........and is working.... the new DVD machine should have red, white and yellow RCA cable.... connect these to the correct DVD outlets ........now connect it to the TV (digital IN)..... this is to view........ now to record using the F connecting cable plug this into the DVD (rear top right hand corner) this should be coming from your sat/cable out ........... now from the DVD F connector out .this goes to the TV...........note to record from another DVD player use the front jacks.........turn the power on and enjoy that movie(s)
Jan 27, 2011 | Toshiba Televison & Video
Need universal remote control code
Hello
Three digit universal remote control codes for Toshiba are:-
013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Four digit universal remote control code for Toshiba are:-
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Dec 03, 2010 | Toshiba MW27FPX 27 in. TV/VCR/DVD Combo
Toshiba TV/VCR/DVD combo (MW20F51) won't read/play dvds.
this a laser unit dirty or dead, needs to be cleaned with a laser cleaner kit or replace the laser unit
Feb 19, 2010 | Televison & Video
Toshiba Model 42HM66 DLP Projection TV
I strongly doubt it's the lamp assy since you can actually see the blue screen. If the lamp failed, you would not see anything on the screen. This blue screen indicates to me that either the tuner is no longer decoding the signal, in improper input has been selected (ie: input 1 is selected while actual signal is on composite 1), or something of that nature. If you are getting audio then the input is selected properly but the video decoder has failed.
If your cable signal is going through a VCR or DVD, disconnect it from there and go directly to the TV (ie: bypass the VCR/DVD). If your picture comes back, there's some kind of problem with your VCR/DVD player.
If you have multiple inputs, try connecting an input signal to another input (ie: video 1, or aux from a dvd player) and see if you get a picture there. If you do get a picture, the whatever input you're currently using has malfunctioned.
Mar 08, 2008 | Televison & Video
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Oct 16, 2006 | Sony KV-32S25 32" TV
Toshiba 65H82 65" Rear Projection Television Logo
114 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
