Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore Elite model 73503201- FRIDGE DOES NOT COOL, FREEZER WORKS
The refrigerator upper section has stopped cooling. The bottom freezer section stills works fine. The cooling fan behind the back section of the unit still works and the coils have been vacuumed clean.
    Scholar:
  • 31 Answers
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
I have a kenmore coldspot side by side refrigerator model#106.57372700 it's not getting cold on either side is there a reset button
Kenmore Elite Coldspot Side by Side Diffuser (1of2 ...
? 10:00
https://www.youtube.com/watch?v=iND0eR_WlQs
May 16, 2012 - Uploaded by Your32Maker
Kenmore Elite Coldspot Diffuser replacement. ... RefrigeratorRepair - Fresh Food Section Is Not Cooling , Kenmore , Whirlpool -59672213200 ...
Refrigerator Repair - Not cooling,Repair & Diagnostic ...
? 12:12
https://www.youtube.com/watch?v=2yXK6aQ0uuE
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Fix a Kenmore Refrigerator suffering from some of the following symptoms: ... Not cooling,Repair & Diagnostic - Whirlpool,Kenmore 10671192101 ... Litton, Magic Chef, Montgomery Ward, Ikea, Cold Spot, Crosley, ESTATE, ...
Kenmore Coldspot side by side fridge/freezer not cooling the
www.justanswer.com > Appliance
Question - Kenmore Coldspot side by side fridge/freezer not cooling the - HI. Find the answer to this and other Appliance questions on JustAnswer.
Kenmore Side by Side fridge not cooling? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 16, 2013 - Hello! I have a 10 year old Kenmore Coldspot Side by Side model # 597799990 that stopped cooling on the fridge side. The freezer works fine.
kenmore coldspot is not cooling ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Jan 24, 2016 | Kenmore Refrigerators
Freezer fine but fridge warm
The fan seems to be out looks like you need a new fan motor for freezer component
Nov 14, 2013 | GE PDS22SIS Bottom Freezer Refrigerator
Kenmore elite trio 596 73503201
This happened on my side-by-side. There is a damper at the inside top of the refrigerator compartment that was failing to open to allow cold air in. I took the cover off and propped open the damper while I ordered the part and waited for it to arrive. Problem solved and hope to keep it running another few years.
Nov 13, 2013 | Kenmore Refrigerators
Fridge not cooling... Freezer is fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Sep 12, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The refrigerator section is not cooling. The freezer section work fine. What is the problem?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer works, upper section not cooling on Kenmore bottom freezer.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 06, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
My freezer area works fine, but the fridge stops and starts working continually does anyone please have a solution
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 26, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
382 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Richard Roth
Richard Roth
deton8 von Splosion
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
