Question about Panasonic Televison & Video
NO POWER OR LIGHTS WHEN POWER BUTTON PUSHED
MY PANASONIC CT-27SL13 IS COMPLETLY DEAD. NOTHING HAPPENS WHEN YOU PRESS POWER BUTTON . IS THERE A FUSE OR SOMETHING TO LOOK FOR
    Problem Solver:
  • 14 Answers
Hello and welcome to FixYa!,
It sounds like the Power Board on you TV has Died, you will need to replace it in order for your TV to work again
Hope this helps --Full Str Pka
Posted on Dec 30, 2008
32'' Panasonic television. Power switch does not turn the set on.
1 It appears that connecting cable is faulty. Normally when you connect and push the power switch the standby light should lit. Try the cable on another appliance and see its function. Also switch on the TV and try to switch it on with your remote control.
Nov 19, 2009 | Televison & Video
The TV will not power on at all
Is the set completely dead? if so you should see no indicator lights and hear no "click' when the power button is pressed. If so than the only thing wrong with the set ic the main Fuse (6.3A 250VAC) has blown.
Sep 19, 2009 | Panasonic CT-32HC14 32" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Picture on and off
these arent easy fixes,have them serviced
May 19, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
TV won't turn on. (Panasonic 1080i HDTV)
By the sound of it its a dead power supply im afraid :( It is very common for them models at that age very common... it may be cheaper to fix then buying a new one but ill let you decide that one but yea theres hundreds of people that have the same problem with them panasonic's bummer dude :(
May 04, 2017 | Panasonic CT-30WC14 30" TV
My TH-42PX6U TV went completly dead
Ok, I hope to save you a lot of money. I finally figured it out. There are a lot of hints on the web. Once you get it fixed you will regocnize them. So here is what I did. Had to order the 2 fuses for the main power board from panasonic. The fuse number is K5D802BNA005. You only need two. Once I changed the 2 fuses I go the tv to power up but the red light blinked 10 times. This indicated there is a power problem.
There is a high probability the P board is bad. You can check this by checking th voltage on the number one pin on the p10 connector. TO do this you have to measure the voltage as you power the TV up. you should get 14 volts. if not the board is bad. I bought one on Ebay for $120. Put it in and it works. good luck.
Feb 25, 2009 | Panasonic TH-42PX60U Television
Panasonic TX14S2T
What are the symptoms? Is the set dead? Please clarify
model number from back of set...The red power light coming on means the AC fuse is OK, but the B+ fuse may be bad. If that
is true,check the horiz o/p xistor and get back to me....T.
Oct 20, 2007 | Panasonic CT-27G14 27" TV
Panasonic CT-35HL43 36" TV has NO power
it could be the ac fuse gma 6.3 amp my ct-36hl43 did the same thing cost a dollar for the part 99 dollars laborer ragingbass@comcast.net
Sep 30, 2007 | Panasonic CT-36HL43 36" TV
A lot of white noise appearing on Panasonic CT-27SL13 27 using COMCAST
You maist likely have bad ground connections inside the tuner of this TV set. Good Luck
Jun 23, 2007 | Panasonic CT-27SL13 27" TV
Televison & Video Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
