Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door will not close
I opened garage door with remote then tried to close with remote and fixed button would not close light bright switch clicks at motor but does not activate. both door sensors green.
what could be the problem ? I have no manuals operator was installed when we bought the house last year 2007 remote says 02/99 K1026
  • 2 more comments
  • leslierpeter Jan 01, 2009
    Door Tech: If holding the button as you described works, what does that indicate the problem is?
  • jhmart Jan 03, 2009
    I had the same problem, replaced the sensors, worked fine after for about two days, now the same problem is back.
  • linpaporello Mar 21, 2009
    Sears/Craftman K1026 6/94 139.53779, HBW0709 That's all the info on the remote. Remote will open, but not close the garage door. Button on wall will close it only if I hold it till door touches the ground. When I try to close it with the remote, the light flashes and it tries to start but that's the extent of it. Nothing is blocking the sensors. Tried to set the remote following the directions on the motor, no luck HELP
  • Joseph Chapman
    Joseph Chapman May 11, 2010
    If you hold the button on the wall until the door goes all the way to the floor, will the door close?
    Sniper:
  • 98 Answers
If you hold the wall button down and the door closes the problem is photo eyes.
Posted on Jan 03, 2009
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
No reponse when using the remote, the wall control works fine.
The remotes use a receiver to actuate the door and the wall control does not. It sounds like your logic board is bad. Maybe a lightning storm recently? Try removing the board and look for burnt or missing traces on the printed circuit.
Sep 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have 2 liftmaster 3245. The hand held remotes were working fine then stopped. I replaced the batteries and turned of all electrical/RIF close by. Still not working. Both cars operate the doors with no...
You need to reprogram the remotes by briefly pushing the learn button on the garage door opener until it flashes once, then release the button on the garage door opener.
Now press the remote button once until you hear the garage door opener click, now press the remote button once again and the remote should be programmed to work for that garage door opener.
DO NOT press and hold the garage door opener learn button for more than 10 seconds or you'll erase all programs and have to relearn all the remotes, including your car ones.
Hope you found this very helpful and best regards.
Aug 06, 2009 | liftmaster Chamberlain Garage Door Opener...
Same problem, but no garage door sensors
Both the remote and the manual button once set a relay that applied power until the door had reached one or the other 'stops.' That relay, or the transistor that controls it, has failed, making it necessary to keep the relay powered by holding the button. It's probably repairable and remotes for just about any system are still quite available.
Heartland America, a catalog company, has offered a 'universal' garage door remote for some years; something that bothers the heck out of me.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener remte built in in my van suddenly stopped
TRY DISCONNECTING THE WIRE TO THE WALL BUTTON. IF THE VISOR REMOTE NOW WORKS YOU HAVE A BAD BUTTON.
HOPE THIS HELPS
Jul 30, 2009 | liftmaster Chamberlain Garage Door Opener...
My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
Jun 19, 2009 | liftmaster Chamberlain Garage Door Opener...
How do I re-code my Raynor Garage door opener Model 61 rdg (on Remote) Serial # 17592 (on opener) Year 1992? I am a new resident in the house with this garage door opener. The remote control opener worked...
on the back of your garage door opener there is a colored learn button--press and release-the learn indicator light will glow for a short time usually 30 seconds. within thirty seconds press and hold the buton on the hand held remote that you wish to operate your garage door. release the button when the motor unit lights blink. if you don;t have a light, two clicks will be heard. it has learned the code. procedure will be different for multi function control.
Apr 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door opener
Pop open the cover and check for loose wiring. Also check to see if the capacitor is still good that powers the motor.
Apr 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
554 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
