I have a problem with my camera shutting off when trying to view pictures taken or trying to upload the pictures. At first I thought it was a problem with the camera, but when I take the memory card out, the camera works just fine. Also, when I inserted the memory card into someone elses new camera (same make and model) it made their camera react the same way. The memory card was inserted into a friend computer slot for reading cards. I don't know if this could have infected the card or not. Is it possible the the card is now defective or dirty? Is there a way of cleaning a card. Would a new card solve the problem?
I had the exact same problem, and i had no luck finding a solution, so i was messing around with it, and i figured out what the issue was.
Go to Menu and then to the SETUP option.
When you scroll down there should be a USB option.
Change it from Digital Camera to Disk Drive, and your computer/camera will register that it has a card in it!
Check to see whether you are saving them to an unusual location on the CF card. If you are finding the image files from the card but just cannot open them, you may have taken the pictures as "raw" format images. If they are in "raw" format, you may need special software to open them on the computer.
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom. Once you select your option, choose your pictures and copy.
http://www.samsungcamera.com/popup/download.asp?prj_uid=741&prol_uid=4153
Download the english manual version pdf file and open with adobe reader go to page 84.
When you upload a file that is not taken by this camera to the removable disk, the [File Error!] message will be displayed on the LCD monitor in the play mode, and nothing is displayed in the THUMBNAIL mode.
Make sure that the memory card is formated in the camera not the memory card reader on the computer. Make sure you save your edited files in jpeg file format. Avi for movies. The manual makes it sound like the camera will not read altered files or files not taken by the camera itself. edited files are not files taken by the camera. Good luck I hope this helps.
Please rate me.
You problem set your camera to use internal memory only. Set the memory function to memory card only and all pictures will go to the memory card until it is full. You can probably still transfer your pic files from internal memory to your card.
I have a Cobra camera (I believe it is an 8500) and when I use it without the memory card, it will take pictures. As soon as I put the memory card in, I can't use it. It says I need to digitalize my camera. I put in the date, time, year. Can't take pictures...
I had a Camedia 560 and it had this problem. Take a picture and then look at your memory card or camera from the computer. I think you will see that there is a complicated structure of folders - the pictures are in one folder and there is some kind of index file in another folder. The camera cannot display pictures restored from the computer unless you restore the index files as well as the picture files. Sorry I can't remember the details, but one way to do it would be to copy every last thing on the memory card. Not very convenient.
This is a design flaw - my new camera doesn't have the problem and will display any picture I copy to it provided it was taken on the camera and not rotated or cropped. It doesn't mind other editing like putting a caption in the photo with a paint program. Panasonic Limix.
