Question about HP Officejet 5610 All-In-One InkJet Printer
Print cartridge carrier for HP C3100 is stuck
I have an HP C3100 all in one printer, scanner, copier, about 2.5 years old, connected to a Mac. Both the check paper and check print cartridge lights are blinking, and it will not print, scan or copy. In trying to troubleshoot the print cartridge, I see that the carrier and cartridges are stuck way over to the left of the printer. I cannot access them. Turning the printer on and off results in some clicking noises, and I can see that the carrier is trying to move over to the right, but it is stuck over in the left, inaccessible.
    Genius:
  • 2,120 Answers
Uneconomical to repair, sorry.
Posted on Dec 30, 2008
How do i install mt inks
Please follow the steps below on how to install/replace ink cartridges on your model:
  1. Make sure the All-In-One is on.
  2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
  3. Grasp the tabs on the cartridge lids, and then lift the lids.
  4. Remove the old cartridges. Store them in an air-tight container or dispose of them.
  5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges.
  6. Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed.
  7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X1270 All-In-One InkJet Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
How to change cartridge on Lexmark 2600 All in One Printer. How does the cartridge come in view so I can change it.
1. Make sure the All-In-One is on. 2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
3. Press down on the cartridge carrier levers. 4. Remove the old cartridges. 5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges. 6. Insert the new cartridges. Make sure the black print cartridge is secure in the left carrier and the color cartridge is secure in the right carrier, and then close the carrier lid. 7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to the power source.
I hope this information has been helpful. Thanks.
Dec 02, 2010 | Lexmark X2500 All-In-One Printer
How to replace ink cartridge
1 Make sure the All-In-One is on. 2 Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy. 3 Grasp the tabs on the cartridge lids, and then lift the lids. 4 Remove the old cartridges. Store them in an air-tight container or dispose of them. 5 If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges. 6 Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed. 7 Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to power source.
Dec 02, 2010 | Lexmark X1270 All-In-One InkJet Printer
How do i change the ink cartridge
Step 1
housing beneath. If done correctly, the print cartridge carrier should move into the loading position near the center of the unit.
Step 2
Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
Step 3
Pull the spent cartridge from the printer.
Step 4
Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
Step 5
Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
Step 6
Close the cartridge lid over the new cartridge until it clicks into place.
Step 7
Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
Step 8
Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
Aug 15, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do i change the black ink cartridge on a lexmark x2580 printer
With printer on and connected to computer do the following:
Open top cover.
Fix top cover on open position, using the plastic sustain part located on the right side inside the printer.
Wait for ink carriage for taking position in the middle of the printer rail.
Open cartridge top cover.
Pull cartridge toward yourself and snap it out.
Do the same in reverse order to fit new cartridge.
Remember to remove cello tape strip from new cartridge nozzle.
Do alignment procedure after replacement.
Sep 11, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Don't know how to install ink
Installing print cartridges
1 Open the printer, and then press down on the cartridge carrier levers.
2 Remove the used print cartridge or cartridges.
3 If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid.
Warning—Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridge.
4 If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid.
5 Close the printer, making sure to keep your hands out from underneath the scanner unit.
Removing a used print cartridge
1 Make sure the printer is on.
2 Lift the scanner unit.
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid.
4 Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Apr 13, 2009 | Lexmark X4650 InkJet Printer
Dell926
Clear Carrier JamThese are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges.
Regards
Chittaranjan
Dec 14, 2008 | Dell 926 All-In-One InkJet Printer
Replace ink cartridge
The print cartridge carrier moves and stops at the loading position.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
5 Remove the stickers and transparent tape from the bottom of the cartridges.
6 Insert the new cartridge. Make sure the color print cartridge is
secure in the left carrier and then snap the lid closed.
If you are installing a black print cartridge, make sure that it is
secure in the right carrier, and then snap the lid closed.
Mar 02, 2008 | Lexmark X1150 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
298 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
