Failed hard drive
Can take the data disk out of one hard drive and put it in another one of the same model ?
  • leon2161 Dec 31, 2008
    I have the same problem with a paraguda hdd 640MB and I don't want to loose data. If in case I get the same hdd and change the disks inside from the defective one, can I get the data??
    President:
  • 948 Answers
It is possible, but you will need the EXACT same model, down to the component board revision in some cases. And those can be very hard to find. One thing you can try is put the drive in the freezer overnight (in an airtight bag of course). Then install the dive in an external tray as extra storage, it may work long enough to get the data you need. If you can use an external tray with a USB interface you can hot swap so the drive runs as little as possible.
Here is one possible enclosure - http://www.newegg.com/Product/Product.aspx?Item=N82E16817153066
Posted on Dec 31, 2008
    President:
  • 2,692 Answers
If i understand correctly, the HD you have now is not damaged in any manner  and you want to transfer the hd to another computer.
If it has an windows OS on it almost al the hard ware including the cpu woudl have to be exactly the same . then the answer is yes. If it is a data ont drive w/o and win OS . then yes any computer as a slave or extra drive.
If refering to moving the data from one disk to another using the same computer wanting a new Hard drive with the windows on it the answer is yeas but it take special software such as TRUE IMAGE home as an example.
I hope I understood corrctly. If not please let me know.
How do i fix
There is a problem with the data on the hard drive, or the hard drive has failed.
1) if you have valuable files buy a usb to ide kit
take out the hard drive and put it into the usb to ide and
connect the whole assembled kit to a working pc to extract
any files (where possible)
2) put the hard drive back in the machine and install windows again using recovery disk supplied with your machine.... if this failes then it could be because....
hard drives failed
motherboards failed
Nov 03, 2013 | Computers & Internet
Hard disk 1 (3f1) error on HP pavillion dm1 series
So, can you see it in My Computer? If yes, get your data off the drive and format it!
If you can't access your files,data recovery software can help.I used this one called Tenorshare Data Recovery to retrieve files off crashed HDD and it worked.
If needed,you can download it and scan your hard drive for free to preview whether your files can be recovered.Get it from http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Apr 21, 2012 | Computers & Internet
Hard Drive Crash - wants to re-install how to retrieve data to laptop computer
If the HDD has failed you can't retrieve the data off the failed drive. You can send the HDD into a data recovery company and they will read the disk in the drive and put the info on DVD and sent it to you, but that is the only way. The service is quite expensive. Just do a google search for failed hard drive data recovery.
Jan 27, 2012 | Computers & Internet
Dell inspiron 1525 can't boot up, keeps on saying hard drive cannot be found. What could be the problem. Tried safe mode and it did not work, tried installing the operating system again without luck,...
please check if you can remove and reinsert the hard drive from its's location. usually you would have to remove 3 or 4 screws on the bottom part of the laptop and slide the hard drive out. once it's out put it back in and make sure that it's tightly on its place.
If this does not work you may have to replace the hard drive because the message means that it cannot detect the hard drive and it might just have to be replaced.
Jun 07, 2011 | Dell Inspiron 1521 Notebook
I need reset
Looks like you have a major problem.
If the notebook can not start from a fresh reboot, then you may need to restore the entire system from either the restore partition on the hard drive, or from the supplier's Restore CD-ROM (disk).
Be warned that a full system restore will "wipe" all your data from the hard drive.
Before you do that:
FIRST STEP: If the hard drive is still operational, you will probably still be able to get to all your useful data and make a copy of it. Then you can perform a system restore/install and transfer the data back to the newly-installed system's hard drive.
If you need to access the data on the laptop in a hurry, then the easiest thing to do is get access to another (2nd) computer, take out the hard drive from the failed laptop, put it into a portable drive carrier with USB connection (you can buy this from a computer shop) and access the data on the hard drive that way via the 2nd computer. That can be a real help when your laptop is not working and I have used it on several occasions when I or my customers have had a broken/failed laptop.
SECOND STEP: Once you have copied all your data that you need from the failed laptop's hard drive, you can put it back in the laptop and perform a system restore/install and after that transfer the data back to the newly-installed system's hard drive.
Mar 20, 2011 | ASUS F3Jc-AP141C Notebook
2 HD's installed in Dell Studio XPS 8100. Keep getting error message that one of the drives has failed but when I do a scan with dell support center it shows everything OK. Dell customer support said the...
Have you configured the two disk-drives to "mirror" each other, i.e., write every block of data to both disk-drives? If so, then one of the two disk-drives has "failed" -- it is not recording the data,
and all your data is _only_ available from the _one_ disk-drive. So, you need to identify which of the two disk-drives has failed, and you need to buy a replacement disk-drive. Then, use the "mirroring" software to copy everything from the "good" disk-drive to the "new" disk-drive, to re-establish the "mirroring". Do this before your _second_ disk-drive _also_ fails!
Mar 17, 2011 | Western Digital (WD5000AAKS) 500 GB SATA...
When i boot it always says "hard Disk: S.M.A.R.T. command failed press f1 to resume"
this means the hard disks start up self check has failed. press F1 then backup all data from your pc to another drive.
You will then have to replace the drive.
Feb 28, 2011 | Samsung (SP0411N) 40 GB Hard Drive
Unit failed to boot and observe the followng; - No start-up display - No CMOS boot-up display - Hard disk clicking sound and OS won't start
Turn the computer off.
Disconnect the AC power supply.
Remove the battery.
Remove the disk-drive.
Reconnect the AC power supply.
Turn the computer on.
Put any "data" disk into the CD-drive.
Does it display the CMOS boot-up display?
Can you hear the PC try to spin that "data" CD, i.e., trying to "boot" from it?
If it works "better" without the disk-drive attached, the disk-drive is the problem.
Jan 11, 2011 | Toshiba Satellite A105 Notebook
Portable hard disk fell its not being recognised
The drive has failed, Contact the manufacturer for a replacement and if u need the data back, contact a data recovery company :)
Apr 14, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
The bios test of hard disk test is failed wht can i do now
If the hard disk has failed, and you want the data off of the hard disk, you have two choices..
Purchase a extender to allow you to read the hard disk and also purchase a data recovery program to get the data off the hard disk...
Or google data recovery service and find one that can retrieve data of of bad hard drives..
Either way afterward you will need to purchase a new hard drive.. They have drives as low as 30 dollars online that can be purchased and then installed.
You will need to reinstall windows on the new hard drive you get..
Ultimately you will have to weigh the cost of repairing the computer ( purchasing a hardrive and purchasing a new copy of windows)
Versus purchasing a new computer.
Oct 31, 2009 | HP Compaq nx9030 Notebook
Computers & Internet Logo
112 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
