Question about Dell Dimension 3000 PC Desktop
I'm getting a message saying ''primary drive 0 not found''
When first turning on my computer
    Novelist:
  • 101 Answers
Either the BIOS is not configured to sense the connector where your hard drive is attached or the drive is dead and unreadable.
Start the machine and press F2 when you see the Dell logo. This should get you into the BIOS setup. Come down to Drive Information and see if your HDD is listed under IDE1 (or Primary Master). The BIOS should list the model number and capacity. If IDE1 is off or disabled, change the setting, reboot and go back into BIOS. If you still can not see the HDD in BIOS, remove it and put it as a secondary drive in a different machine to see if it comes up. If not, you have a dead drive.
Posted on Dec 30, 2008
4 Suggested Answers
  • 9 Answers
SOURCE: My Dell will not start
If you any experience getting into the system bios you can check to see if the system still sees the hard drive by pressing the F2 or DEL key on startup. This screen shows a system bios with hard drives present. ( http://techgage.com/reviews/asus/barebone_690/pundit_21_thumb.jpg ). If it does not show up it could be that it came unplugged however unlikely. But you could try opening the system and checking to make sure the hard drive is still plugged in. Some manufactures tend to plug devices in fairly loosely. It may look something like this (http://www.laray.com/build/drive5.jpg) or like this (http://lib.store.yahoo.net/lib/cooldrives/ide-drive-to-sata-adapter-plug-image-2.jpg)
If all this seems too much, you could take the PC to a repair shop and have them check to see if your harddrive is still properly installed. If it is still installed but keeps giving that error then you probably need a new hard drive.
Posted on Dec 09, 2008
byron21
  • 151 Answers
SOURCE: Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Posted on Sep 24, 2009
  • 164 Answers
SOURCE: Dell: Primary hard drive 0 not found Primary
Sorry, but this isn't a good sign. Drive 0 is most likely your main hard drive, and only if you have a second one would you computer ever find anything on Drive 1.
I would check the connections inside from the motherboard to the hard drive, as well as from the power supply to the hard drive.
Here's the manual: http://support.dell.com/support/edocs/systems/opgx60/en/ug/sffabout.htm#1103481
Also, if you boot your computer to the Dell copy of Windows, go through the motions of reinstalling Windows and you probably won't be able to detect any drive to install it on.
You'll most likely need to replace the hard drive altogether. Sorry!
Hope this was helpful for you (even though it was bad news)! If so, please give a rating!
Posted on Mar 09, 2010
My desktop has crashed and I get a DOS message on the screen that says "primary drive 0 not found"?
Sounds like your hard drive died. Try to unplug the cables to the hard drive and plug them back in. If that doesn't work you may be able to slave the hard drive into another system to see if you can recover any files.
Oct 25, 2010 | Computers & Internet
After I turn on my computer I get a message that says; Primary drive 0 not found, primary drive 1 not found, secondary drive 1 not found, strike f1 key to continue, f2 to run the setup utility.
If you have a spare working hard drive to test in this computer, swap it out with the existing one. All you have to do is verify that a drive is found during the post. If you get the same message, I would suspect the IDE controller on the motherboard has failed. With the age of the computer (5 years), I would suggest getting a new or used computer to replace it. You may be able to find a replacement motherboard for it, but then to keep it legal with a Windows operating system, you have to locate a motherboard of the same make/model.
Aug 26, 2010 | Dell Dimension 3000 PC Desktop
Mar 09, 2010 | Dell Optiplex GX60 PC Desktop
Hi My hard drive crashed can it is old can it be
Most likely scenario is the drive is dead, but also the BIOS on your computer is old itself, I believe there are a few BIOS upgrades available for that model, might want to check with Dell support site. If you have access to another computer, there is a way to check your drive. Go to a computer retail store or on Ebay, but a EIDE/SATA to USB adapter. This will allow you to take a hard drive out of the case and attach this adpter to it and plug the usb side into another computer, laptop, doesn't matter...that computer will read the drive as an external hard drive....if the drive is indeed still viable. If it is, this would be a good time to save your files to the other computer for safe keeping until you can get your other system back on its feet.
Oct 10, 2009 | Dell Dimension 4600 PC Desktop
Try doing the ff:
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Dell optiplex gx110 device detection problem
I'm guessing that the computer is not booting at all. This is saying that it cannot find any hard drive to talk to. Drives are labeled in the computer code with numbers starting at 0. There are up to 2 drives on an IDE ribbon cable, the Primary, and the "slave" or secondary. So, possibilities are that your hard drive died, the power connector to it came loose, or the power supply itself is having an issue with that connection that is attached to the hard drive.
Jun 11, 2009 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
DRIVE 1 NOT FOUND, PATA 0
One of your settings in the BIOS is set to look for a drive and it is not finding it. That is what that message means. If you have multiple drives in this machine then one of them has failed. If you only have one drive then the settings are set to look for a drive and it is not finding it. To fix this reboot the computer. When you see the DELL logo press F2 to get into setup. Then go down to Drives and turn off any drives that are set to Auto, except for your C: drive which should either be SATA 0 or PATA 0. Since it is not saying that SATA 0 is not found then I suspect your main drive is on the SATA 0 channel. Go to SATA 1 and turn it off. The instructions should be on the screen. Usually you select it by moving the arrows and then hit enter, you then use the arrows to select off. If your CD-ROM/DVD ROM is not on PATA 0 then turn it off as well. If you need more advice let me know.
Apr 28, 2009 | Dell Dimension 5100C (D51CL1) PC Desktop
Dell Dimension 8250
Yes you need a new hard drive
Dec 09, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 3000 PC Desktop Logo
419 people viewed this question
Alun Cox
