Question about Philips Magnavox 51MP392H Rear Projection Television
There is a picture but it is blurry with a big yellow blur.
The tv has great sound but the picture is blurry and right in the middle is a big yellow spot.
  • Anonymous Mar 26, 2009
    same here ive adjusted brightness color tint and the picturte is till dim and blurry and the yellow spot is noticable more on white screens
  • Philips Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiThere is a picture but it is blurry with a big yel - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
There is a picture but it is blurry with a big yel - 578ba6c.jpgef="http://www.fixya.com/support/t1631691-red_aura_in_middle_55_phillips#" >Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 29, 2009
Hi there I have just purchased a LG LX9500. This is a great TV, wow. But I am experiencing one issue. When subjects are moving or being panned across the picture appears "ribbed" or another way to...
trumotion on or off.. try adjusting the blur and judder setting in the picture menu...
banding is common on this set during panning scenes, but it sound like you are descibing trumotion artifacts.
Sep 15, 2010 | LG Televison & Video
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Aug 11, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Moving objects extremely blurry in SAMSUNG LCD-football, golf,etc
This is a problem that will pretty much just be there on this TV. I know it has an awesome picture...as long as nothing moves. You can try putting it in "Game Mode" in the user menu and that usually takes care of it but you didn't buy the 120/240 Hz tv to watch it in 60Hz. I would say exchange it, and in my opinion buy a good plasma :)
Jul 08, 2009 | Samsung LN55B650 55 in. LCD HDTV
Fuzzy background on tv picture
This is probably a combination of 2 things. In both causes 1 and 2 below, I would suggest checking the TV with a BluRay Player with BluRay disc connected using an HDMI Cable. If you complain about this, then the TV is probably not that great. Expect a $200 jump to a better model at the least (but this depends on what you have now). Honestly, this is fairly normal and wont change much with the next TV.
CAUSE 1: Motion BLUR
Motion blur occurs when fast moving objects are displayed on LCD TVs. Basically, it takes time for the LED lights that make up the picture to turn ON and OFF, when and object shown on the TV is moving faster than the LCD TV can turn these lights ON and OFF, you see the trail left behind as the lights dim to OFF. This look like blur because you see the current image and the trail of the old images. 120HZ and 240HZ LCD TV are supposed to improve this but honestly, they are at times 300+ dollars more and not really worth it. Very little difference except in some few cases.
CAUSE 2: Digital TV
Digital signals are hit or miss. Good or BAD. If you are watching Cable, Satelite or Antenna; it is likely you are seeing some BLOCK NOISE. This block noise is caused by missing information or Noise in the video signal. This will cause the picture to Pixilate (you see blocks and things start looking blurry too). This happens with poor signals. This also happens with the HD channels when they have more information than bandwidth (more data than that have space to send it...image shoving an elephant into a VolksWagon Beetle)
May 27, 2009 | Televison & Video
Gray picture
This sounds like you have the contrast setting too high, go to your menu and find the contrast settings, and adjust to your requirement. As for the words being blurry, this could be because your tv is HD ready, and unless you view a High Definition channel then the picture will be a liitle blurred.
Hope this is of some help?
Sep 16, 2008 | Samsung DynaFlat TX-P3064W 30" TV
Yellow screen on tv
lots of times when you go and buy your tv's for example like big screen... usually it will tell you that you shouldn't play like play station and things like that on them and i don't know why...
Dec 05, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Picture is blurry, but perfect sound
Sounds like a ground leg on the distribution block has loosened up and is not properly grounding the screen drive. worst-case scenario is that ione of the tubes (3 picture tubes) has started to short out and is causing the blur.
Nov 08, 2007 | Toshiba TP61G90 61" Rear Projection...
Picture good in middle, blurry on sides
sounds like a a convergence problem.............does your tv have an auto-convergence program in the set-up menu?
Oct 22, 2007 | Samsung HCM422W 42" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
153 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
